fretboard attachement
DaveW
Post by DaveW » Wed Feb 20, 2013 9:05 pm
Hi people
Im in the process of a build at the moment and have been doing a bit of experimentation /learning and are thinking of attaching the fretboard to the soundboard mechanically.
Ive seen the way Taylor do it but that seems overkill to me ,and I dont have a CNC machine
I was thinking of just some 1/8 countersunk metal threads drilled through the fretboard and soundboard ,epoxied into the fretboard and just nuts and washers and a wood shim underneath the soundboard ,the metal thread heads would then be covered with shell dot inlays as fret markers,depends on how I would want to mark the frets there is scope to use 1,2 or 4 or 5 screws ,
is this a stupid idea ?
the reasoning is so that the neck is completely removable , I am using a mortise and tenon neck joint
or would it just be better in your collective opinions to just glue it ?
Re: fretboard attachement
Post by Trevor Gore » Wed Feb 20, 2013 9:26 pm
Use a double MT like this. No CNC required.
DaveW
Post by DaveW » Wed Feb 20, 2013 11:50 pm
yeah that looks really simple Trev ??
Im afraid my build has progressed beyond being able to attempt a "simple" join like that
Post by Trevor Gore » Thu Feb 21, 2013 9:57 am
Start with a normal single MT joint, bolt on the neck, get the alignment right, rout a pocket for the neck extension across the neck and the body, drop in the loose tenon. Dismantle the joint, glue the loose tenon to the neck only, fit the screw inserts (T-nuts), glue on the fretboard.
What's hard about that? :D
It's a great joint when well done. Can go from strung and tuned to neck off in less than 5 minutes and most of that is getting the strings off.
Full details (pages and pages, text and pics for SS and CL joints) in the usual place.
ckngumbo
Post by ckngumbo » Thu Feb 21, 2013 10:38 am
trevtheshed wrote:Use a double MT like this. No CNC required.
Elegant thanks for posting thisE
Crafty Fox
Post by Crafty Fox » Sat Feb 23, 2013 11:25 am
That's so neat; I think I'll give it a go. Thanks for sharing.
Ken
Post by kiwigeo » Sat Feb 23, 2013 1:19 pm
Geeeeeeeeeet the boooooooooooks :)
DaveW
Post by DaveW » Sat Feb 23, 2013 9:01 pm
IIIIIIIIIIIIIIIIII Haaaaaaaaaaaaaaaaaaavvvvvvvveeeeeeeeee
Crafty Fox
Post by Crafty Fox » Sat Feb 23, 2013 10:07 pm
kiwigeo wrote:Geeeeeeeeeet the boooooooooooks :)
Grrrrrrrrrrrrrrrrrrrrrrreeeeeeeeeeeaaaaaaaaaaat ideaaaaaaaaaaaaaaaaaaaaa; and it's my birthday soooooooooooooooooooon!
Ken
Users browsing this forum: No registered users and 849 guests
