Hi Chris and welcome from the Wood rodent too! I have been using my little climate room/go bar enclosure now for a couple of weeks and I can say that I am glad that I spent the time (and money!) to build it as it is so easy to control the humidity and the humidifier does not fill up nearly as fast as with the larger space I used before. Although I cant walk around the other side to get to squeeze out I can see it through the windows, I have enough access all around to get it all.chris paulick wrote:Pretty cool idea. Any way you could make it a spray booth too?![]()
I hope you don't mind, a bit off subject but do most of you all have your decks where you can't walk around it? Mine is located on my island bench so I can walk around the other side if I need too. I find it helps when cleaning the squeeze out.
Localele wrote:Trouble is someones been leaving tools and stuff everywhere already Hesh will have a heart attack.
Users browsing this forum: Google and 166 guests
