Finishing Options
Post by sebastiaan56 » Mon Jan 12, 2009 9:57 am
Ive also had mixed results with Wattyl Estapol Tung Oil, I think its for floors, I swooged the first couple of coats with blonde shellac and really spirited off to get it nice and shiny and then overcoated with the Tung Oil. Four coats wiped on. It appears to be very hard, but a bit dull. I polished it with some Meguiars #7 and then Carnuba but its still a bit flat.
I think Tru Oil is great but a bit exy for me at the moment, I havent tried the revised Hard Shellac. I look forward to your comments Graham.
Pete Brown
Post by Pete Brown » Mon Jan 12, 2009 10:16 am
It has a use-by date of 3/2010, and I was wondering in anybody knew when Ubeaut started using the new formula? No-one answering the phone there this morning.
I had exactly the same question but, like Graham, was unable to get them on the phone, their preferred method of contact!
My own bottle has the same use-by date as Graham's and after reading on their web site later that it has a shelf life of 18 months, I figure it must have been bottled in September 2008, well after the introduction of the plasticiser.
I was a little inattentive yesterday while spraying a 2 pound cut, and lingered momentarily with the gun over a very small area of the headstock. I knew at once that the finish had been laid on too thickly as it sagged there very slightly. Within minutes it had crazed! I managed a thin even coat over the rest of the neck and it looks just fine.
I'm not about blame the product for my sloppy technique yesterday. No product is entirely forgiving and I'm sure it'll be a matter of refining my spraying technique and getting to know what the Hard Shellac will and won't put up with. The jury is definitely still out, and will be for some time.
Post by ozziebluesman » Mon Jan 12, 2009 10:26 am
Graham: I did some reasearch on the new formula Ubeaut Hard Shellac and purchased my bottle on the 1/7/2008. The product had just been released on to the market! My bottle has a use by date on it 1/1/2010.
graham mcdonald
Post by graham mcdonald » Mon Jan 12, 2009 11:26 am
I got onto Carol's woodwork supply who sold me the bottle, and they said it turns over pretty quickly and that batch would have only come in a few weeks ago. A good warning about spraying it on too thick. From memory I cut the last lot a fair bit with alcohol to spray it, probably to about 2 parts HS to 1 part alcohol. The trick with spraying ordinary shellac I have found in the past is to use minimum pressure, otherwise the alcohol could evaporate before it hit the surface and you end up with lots of little dried lumps of shellac and not much else.
I saw something recently about using acetone to thin shellac for spraying. Can't find the reference, but does anyone know anything about this?
graham
Graham McDonald
Post by DarwinStrings » Mon Jan 12, 2009 11:37 am
John FM wrote:I am reckoning that if it's good enough for preserving gun stocks that get a fair bit of rough treatment, why not apply it to instruments!!
I agree with you here in part John. Also with Peters wife in that if you find a product that works, well, then sell it, after all you are the builder and should be prepared to stand behind your product.
Guns stock or solid body guitars. Same difference, a chunk of hardwood. My problem with oils is when you apply it to softwood acoustic soundboards.
I have been putting tung oil on coffee tables and kitchen bench tops for 17 years. Not the type of tung oil that Sebastiaan is talking about as most tung oils are mixed with linseed or other oils (to make them easier to use) then a solvent like mineral turps or naptha(white spirits). I buy pure tung oil which is nothing but oil straight from the nut and has no know toxicity. As a solvent I choose gum turps but you can use anything really, nasty old naptha seems to be a popular choice.
Tung oil is said to be the hardest and most water resistant of all wood finishing oils and is also easy to repair. Kitchen bench tops that i made 15 years ago are still in service as well as coffee tables that cop a beating.
Here is a solid body that I have used pure tung oil on. I sanded the wood then used a grain filler but wiped it back hard as I wanted the grain to show then put on 15 coats of the oil, one per day hand rubbed with no sanding or leveling between coats, you can get away with 5 coats but the more you put the harder it gets. I then let it harden and buffed it.
The pic with the tape in it is the gloss at 45 degrees and the other pic is about 30 degrees.
These new shellacs are sounding good too if they dont react with sweat and the humidity of the tropics.
Clancy
Post by Clancy » Mon Jan 12, 2009 2:32 pm
Graham, you've stopped me in my tracks.
I'm off to Sydney on Saturday and was planning to stop by Durobond for NitroC & now I'm wondering if I should wait and see how the Ubeaut Hard Shellac turns out for you.
I'd like to see it get sprayed if I'm able. Are you cutting the Ubeaut with 95% metho or have you found a source of 100%.
By the way, I'm also planning on stopping at Gilet's on Monday if you need me to get you anything.
Post by Bob Connor » Mon Jan 12, 2009 3:16 pm
Graham McDonald wrote:I have got a new bottle of Hard Shellac and I will start on the mandolin in the next week or so. It has a use-by date of 3/2010, and I was wondering in anybody knew when Ubeaut started using the new formula? No-one answering the phone there this morning. It might well have been me who first asked the question about the crazing. It was mid 2007 and they sounded very surprized at the very idea that such crazing could happen. It had to be entirely my fault for spraying it too thickly. As you can imagine I was fairly underwhelmed by their attitude, but the potential for such a product is just too good to dismiss it. Someone did mention that Shines have a similar product out, but I haven't chased it down.
Another very simple finish to consider is Minwax Wipe-on Poly. Bunnings stock it! I used the satin version of it over zpoxy on a guitar with it recently and it is very simple to use. They suggest just using a piece of cloth to apply it and sanding between coats. That left noticeable scratches to I put it on with 600grit wet&dry and it came up very well. If anything a bit too flat, but that could be sorted with some wax I figure. Don't know about the gloss version.
graham
It was around Feb 2008 Graham.
Here is a link to the post I put up shortly after meeting with Neil Ellis to discuss the problem with him.
viewtopic.php?t=414
They are not a large factory. There's just Neil and his wife so he is a bit hard to get hold of at times.
I had problems with it that became apparent some 12 months after applying it. We also tried all manner of thinning it before spraying but the crazing problem still occurred.
I had every intention of trying the new batches but got busy and the Mirotone was working well so I haven't revisited it. I will at some stage when I get unbusy.
Post by sebastiaan56 » Mon Jan 12, 2009 4:15 pm
Toejam wrote:My problem with oils is when you apply it to softwood acoustic soundboards.
TruOil dries hard and doesnt seem to soak very deeply.
Ive just been googling it and there is apparently a risk for those with nut allergies. I find this rather curious as allergenic reactions are normally to proteins, Ive never heard of them from pure oils. Is the oil you use clear Jim?
Im very interested to hear how the Hard Shellac performs,
Pete Brown
Post by Pete Brown » Mon Jan 12, 2009 5:02 pm
My first introduction to Tru-Oil was in the old LMI catalogue which contained an in depth article on using Tru-Oil as an open pore finish, i.e., no pore fill at all on any part of the instrument.
The secret where soundboards is concerned is to wipe the oil onto a small area at a time and immediately wipe off as much as you can in an effort to minimise penetration - you are not trying for a finish build at all.
Much of that article is redundant now that epoxy pore fills are widely used, but for soundboards, it's still relevant.
As if there weren't enough products in the mix, the gunsmith who let me have a small quantity of Tru-Oil some time ago told me he much prefers the oil finishes made by Livos for his high-end gun stocks. I think he uses their Kunos product. They're completely non-toxic and non-allergenic and he reckons they're more durable than Tru-Oil.
Post by Kim » Mon Jan 12, 2009 5:43 pm
Quite a while back someone at the OLF posted the results of an experiment measuring the penetration of True-Oil on spruce. They tried various application methods and then cut the spruce to try and measure the penetration in cross section.
From memory this experiment was done by one of our British friends, or it was one of them which had posted the results. Anyhow, the bottom line was that the penetration was minimal. It would appear that True-Oil is more incline to sit on rather than soak into spruce.
As a precaution, I wiped my top with a very thin wash coat of white dewaxed shellac prior to application and remain confident that the oil has not penetrated the soundboard at all. I have used Tung Oil before and I have used Tung Oil mixed in with polyurethane too, but True-Oil must have some special kind of driers added because it dries much quicker than any other rub finish I have used.
Post by DarwinStrings » Mon Jan 12, 2009 5:53 pm
Hmmm interesting I guess that makes pure tung oil as dangerous as peanut butter :D. Pure tung oil is FDA food contact approved what ever that means when its at home. I don't think you are supposed to drink it though. :shock:
Could I have the link to what you read about allergic reaction to tung oil please Sebastiaan, I had read something on it years ago but the jury was still out and I can't find anything at the moment.
The colour is like a light tan oil colour.
Tung oil also dries hard, much harder than linseed which is what Tru-oil is made from. For me they just are not hard enough to offer the sort of protection that Nitro or other lacquers offers for soundboards.
Pete Brown
Post by Pete Brown » Mon Jan 12, 2009 5:56 pm
And here we all are, striving for that perfect finish... :shock:
That's Willy Nelson's guitar, "Trigger".
Post by DarwinStrings » Mon Jan 12, 2009 8:30 pm
Oops, sorry Pete, I have been calling you "peter" as I thought your were "Peter Brown" from the woodwork forums :oops:
Kim, why don't you want the oil to penetrate the soundboard?
Even the solvents they put in many of those oil finishes help them to dry faster and also Tru-oil states that it is a mixture of linseed and "natural" oils and I know that some products use other oils to speed drying, orange oil is one that is used in some products.
Post by kiwigeo » Mon Jan 12, 2009 10:17 pm
Kim wrote:[As for the True-Oil skinning over in the bottle, it help to keep some marbles handy
Kim.
Ive lost my marbles
James Mc
Post by James Mc » Mon Jan 12, 2009 10:30 pm
I was wondering if anyone has experimented with some of the old traditional varnishes? The old German luthier who got started used shellac as his standard finish but made a bunch of varnishes and finishing oils for special applications. Some, like the amber oil finish, were diabolical concoctions that took a lot of time and effort to make, but others, like copal varnish, weren’t much harder to brew up than shellac. Copal varnish (spirit based) would be harder than shellac and depending on the colour of the copal you use it would be between white and blonde shellac. Mixed 50/50 with white shellac it is as easy to rub on as a French polish.
Graham… The hide glue I got from Gerard last year was the less processed variety used for furniture construction. I guess it does the job but the 192 GS high clarity stuff is considered the best for stringed instruments. It has a bit longer open time, less smell and you aren’t as likely to notice glue lines on tops or backs. All in all I found it much better to use and well worth the few extra dollars. The only places I've found that sell this grade in Australia are Schreuders Music on Ebay or Australian Luthiers Supplies.
Post by Kim » Mon Jan 12, 2009 10:57 pm
Toejam wrote: Kim, why don't you want the oil to penetrate the soundboard?
Good question Jim,
Being someone who has invested a lot of time and effort over the last few years trying to learn and understand all I can about building a steel stringed acoustic guitar, I feel that if I am going to take the time to carefully select, or in some instances, just dump cash on the table in the blind hope that I will be sent the best soundboard material for my guitars, and, then I am going to apply hard won knowledge and acquired skills to the best of my ability in hope that this combination of understanding, theories, and hand skills will allow me to judge the thinning and carving of a top and it's braces to reveal it's full potential. It seems counter productive to me to add yet another confounding variable into the mix which has the potential to not only add more mass than is absolutely necessary to protect my work, but also risk altering the responsiveness I most careful set out to achieve in the first instance.
Seriously not trying to be a smart arse here Jim, it's just honestly how I feel about the process.
Cheers M8
James Mc
Post by James Mc » Mon Jan 12, 2009 10:57 pm
P.S. Check out the local art supply shop for Methylated Spirits (100%). I know that Langridge Artist Colours in Vic sells it.
John Maddison
Post by John Maddison » Mon Jan 12, 2009 11:23 pm
Toejam wrote:Here is a solid body that I have used pure tung oil on.
Hey Jim, where do you buy the oil from ... in Oz? Keen to give it a go as a comparison to linseed-based Tru-Oil. Impressive pix btw.
John M
Post by DarwinStrings » Mon Jan 12, 2009 11:27 pm
Chuckle :D.......Fair play Kim. Well said.
Post by DarwinStrings » Mon Jan 12, 2009 11:34 pm
John it comes from,
http://www.thewoodworks.com.au/site/
They have stuff that I can't find anywhere else, even aniline dye which I almost gave up on finding in Australia.
Pete Brown
Post by Pete Brown » Tue Jan 13, 2009 11:23 am
C'mon guys - this is a finishing thread! :?
Post by Kim » Tue Jan 13, 2009 2:30 pm
Pete Brown wrote:C'mon guys - this is a finishing thread! :?
Fair call Pete,
I have deleted those post from this thread which had gone off track about rabbit glue and moved them via quote to the new topic stated by Graham to keep the peace which is specifically about hide glue. Thanks Graham 8)
viewtopic.php?p=15711#15711
Pete Brown
Post by Pete Brown » Wed Jan 14, 2009 2:31 pm
Graham, I did a search over on the OLF and found the following comments from Robbie O'Brien concerning the Miniwax poly:
Wipe on poly is the same thing as a danish oil but a lot less expensive. The advantage over polymerized oils is that it has polyurethane added as a resin and this gives you more protection. It also dries much harder. This is good on a guitar. It is easily applied, cost effective, adds good protection if built up and available in either gloss or satin.
Great, I thought, before reading the following response from Kevin Gallagher, another luthier whose opinions I always value:
The wipe applied poly is another great finish, but in another woodworking genre. It is soft and not very durable so it works off quickly under a few pick strokes or fingernail strikes.
More food for thought. As is the case with so many aspects of our craft, it all boils down to who you're willing to believe. Or, trying it for yourself and making up your own mind. I bought a tin of the gloss Miniwax this morning prior to reading these opinions and once again I'm scratching my head wondering what the best option is. :roll:
However, with four guitars and a mandolin at the finishing stage, or very close to it, I'm toying with the idea of experimenting a little: the little 12-fret 00 is currently under finish with Hard Shellac; the OM will probably end up with Tru-Oil after reading Kim's post; the Miniwax could go on one of the 000s; don't know yet about the other 000, and the mando will almost certainly be sprayed with Hard Shellac.
Both of the instruments I'll be finishing with Hard Shellac are for my own use, so I'll have plenty of opportunity to assess its durability as time goes on.
graham mcdonald
Post by graham mcdonald » Wed Jan 14, 2009 3:52 pm
Pete,
The great advantage of the wipe-on finishes is that another coat is simple to apply. I only used it on the classical guitar I built because I wanted a quick basic finish, just something to protect it a little. I got the guitar back yesterday from a friend who has been playing it and it does need something extra on it. The soundboard only has a couple of very thin coats and the whole thing needs a little more 'body' to it to get it up to a semi-gloss much like a danish oil finish, which was what I was hoping for.
It does depend on what you want as a final finish. A nitro lacquer is still the standard. You just have to be prepared to do a lot more work (or pay someone to do it for you) to get that look. I am just hoping that a cross-linked shellac can get close. If you don't have to have the smooth film of finish, unblemished by pores and other things that look like wood, the wipe-on oils are fine. It was good to see some confirmation that the stuff doesn't penetrate softwoods very much. I suspected they didn't but had no easy way to check.
We can both report in on progress with the hard shellac!
graham
Graham McDonald
Pete Brown
Post by Pete Brown » Wed Jan 14, 2009 4:19 pm
For anyone who is interested, the thread I quoted from over at the OLF is well worth reading.
http://www.luthiersforum.com/forum/view ... it=miniwax
Graham, how far down the track do you think it will be before you can put your hand on your heart and declare that the crazing problems have been solved? Note that I'm hanging onto the instruments I'm using it on just in case there's yet more tweaking to be done at U-Beaut HQ!
Users browsing this forum: No registered users and 199 guests
