Build a mandolin
- rocket
Re: Build a mandolin
A bit of progress on the A style.
Looks like I've loaded the pics out of sequence but I think you'll get the idea
- rocket
Got the box closed and ready for purfling and binding, nice tight radius around the button!!!'
Also installed the K+K.
Rod
Rod
- ozziebluesman
Watching with great interest Rod.
Looks a treat!
Looks a treat!
- rocket
Used hhg for the back and binding same, a bit messy but got that curly maple binding on now, clean up and scrape the recurve.
- rocket
A style is getting some grain fill and I've got the F back on the bench.
Cheers Rod.
Cheers Rod.
That is completely schmick. Very clean and lovely! Are you sure you haven't done this before.....
Hey Rod,
You have put that wedge-shaped inlay into the top, and the matching sound-hole binding. Is that just because it looks good (it really does, by the way), or is there a story to tell there?
- rocket
You picked it Mark, yeah a moment of stupidity, impatience saw a bit of butchery occur to the otherwise faultless spruce top and rather than try to patch, fill I elected to create a theme with the figured Blackwood to match the tail graft, peghead veneers, back inlay and sound hole bindings.
Cheers.
Cheers.
- rocket
A bit of progress, on to the finish inch stage, base coats are on and ready to apply gloss top coats
Rod
Rod
- rocket
Well a bit has happened since I last posted on this thread, not long after those last pics were taken I dropped the little sucker and split one side from tail to neck. Consequently I swore I’d not build any more, well that wasn’t true coz here I am with a nearly finished mando, check it out!!!
That's a bloody nice finish Rod, well done.
- rocket
Thanks Steve, i still have the F style on the go or should i say ready to be on the go!!
- rocket
Finished
Users browsing this forum: Google, kiwigeo and 222 guests
