Short term solution to the problem....consume a six pack of pale ales (done).
Long term solution......start another neck (do tomorrow)
It's an LMI double acting rod...part of a group buy a few years back.simso wrote:How thick of a trussrod are you fitting into the neck.
Not an option.....others might not twig as to what's going on but I know about the stuff up so unless I fix it it'll haunt me to my graveSteve.T wrote:A long shot, but you could veneer the neck.
Yeah I guess...this is neck number two for this guitar. First neck got trashed while trying to extricate a glued up truss rod...had to replace the fretboard and when it was all done the bolt down tenon was out of kilter enough to prevent the neck bolts lining up properly.Trevor Gore wrote:Glass half full...
Lucky you weren't building in the Spanish method...
My rods are same dimensions.....1/4" width and fit in a 10-11mm deep trench. I did a test rout with a spiral down cut bit earlier on today and got the rod to fit comfortably in an 11mm deep trench. There was none of the filing of the end blocks required when I was fitting the rod into the round bottomed trench produced by the veining cutter.rocket wrote:I've been using LMI da rods Martin, they measured 10 mm deep I cut a slot with a 1/4" straight bit 11mm deep.
That gives me about 3-3.5mm margin.
I know you know how to install a rod but I thought I'd put my two bobs worth in.
Users browsing this forum: Google and 60 guests
