Current Build - Falcate Braced Multiscale OM cutaway
Online
Re: Current Build - Falcate Braced Multiscale OM cutaway
Post by kiwigeo » Mon Jan 04, 2016 11:14 am
Over the last few days I managed to get the neck boltware sorted and the fretboard slotted. Currently Im waiting on a double bearing router cutter to cut out the headstock. In the meantime Im doing my head in thinking about headstock volutes.....one of my Archilles heels when it comes to guitar making.
Cutting fret slots
Cutting nut ledge (compensated nut)
Profiling fretboard
Testing outer string layout and tuner post line up.
Routing pocket for neck bolt down tenon
Shaping bolt down tenon. Trevor does this on a router table....I prefer to do it by hand...because I can :D
Bolt down tenon glued to neck. Prior to glue up I install two 6mm dowel pins to ensure tenon doesnt move when neck comes off the body.
Trimming tenon flush with upper bout. I then had to do a bit of fine tuning to get the neck geometry spot on.
T nuts installed into bolt down tenon. Trevor uses 6mm bolts.....I use 4mm bolts as my neck tenon is a bit narrower than on the plans.
routout
Post by routout » Mon Jan 04, 2016 6:01 pm
Now I get it I like that neck Joint I have not seen before (living under a rock ) nice work for sure.
Online
Post by kiwigeo » Mon Jan 04, 2016 6:08 pm
routout wrote:Now I get it I like that neck Joint I have not seen before (living under a rock ) nice work for sure.
Yeah it looks nice when it's done properly. It can be a P in the A getting the geometry correct but the advantage of this method is you don't get a neck/body "hump" in the fretboard. Frets get pressed in with the fretboard off the neck and then the board is glued to the neck. Minimal to nil fret dressing is required.
Jeremy D
Post by Jeremy D » Mon Jan 04, 2016 8:27 pm
Martin,
Your execution of this joint looks flawless, great work. I have been considering trying this myself but I am not sure my joinery chops are up to the task yet. Do you have much wiggle room for neck alignment with this method? What would happen if you needed to do a neck reset down the track? Bolt on, bolt off neck attachment certainly sounds appealing. Maybe I should go an study the books further :D
Jeremy D
blackalex1952
Post by blackalex1952 » Mon Jan 04, 2016 9:16 pm
Single action truss rod? No CF reinforcement in the neck? What is your opinion re these things? I have found that the CF and dual action directs a lot of the energy that would otherwise be lost from the neck into the soundboard and also allows for finer neck profiles ( if the client wants that ),as the stiffness of the neck is greater. The extra energy available to the soundboard manifests, to my ear, as a stronger attack and longer sustain.If you do use CF in the neck on some of your builds, do you run the CF all the way through the neck extension?
Also: have you hand marked those fret slots, or is there a hidden pin template that we can't see in the pix?
I made all my fretting templates on a milling machine and double sided tape the fretboard blanks to the fret template. The pin holes in the template locate each fretslot on the cutting jig.
Online
Post by kiwigeo » Mon Jan 04, 2016 9:25 pm
Jeremy D wrote:Martin,
Jeremy,
1. Once the bolt down tenon and pocket are fitted there is room for minute adjustments in neck yaw and pitch but it gets messy as you need to mess with the main neck tenon faces and also the sides and/or bottom of the bolt down tenon. It's far easier getting it all right before the bolt down M and T gets done.
2. Neck re-sets. Not covered in The Books but I imagine it would involve routing out the bolt down tenon, doing the adjustments and then making a new bolt down tenon. Not as difficult job as it sounds.
3. The trick to getting the bolt down tenon to fit nicely is the old chalk on the inside of the mortise trick.
Online
Post by kiwigeo » Mon Jan 04, 2016 9:30 pm
blackalex1952 wrote:Single action truss rod? No CF reinforcement in the neck? What is your opinion re these things? I have found that the CF and dual action directs a lot of the energy that would otherwise be lost from the neck into the soundboard and also allows for finer neck profiles ( if the client wants that ),as the stiffness of the neck is greater. The extra energy available to the soundboard manifests, to my ear, as a stronger attack and longer sustain.
1. The truss rod is an LMI double action job. CF reinforcing down the neck.....Ive done it on a few guitars but not on this one.
2. the fret positions were marked out by hand on the paper template stuck to the fretboard. Fret2find supplies you with a PDF option but getting it to print out to correct dimensions involves too much f****ng around with printer settings. I calculated fret positions for outside strings and double checked intersection with centre line against fret2find figures.
blackalex1952
Post by blackalex1952 » Mon Jan 04, 2016 9:35 pm
You may be interested in "Fret Calc" if you have an iPhone...it's free and you just enter the scale length you want and it spits out all the fret distances.
Online
Post by kiwigeo » Tue Jan 05, 2016 8:58 am
blackalex1952 wrote:You may be interested in "Fret Calc" if you have an iPhone...it's free and you just enter the scale length you want and it spits out all the fret distances.
There are a bunch of apps available and they all have their uses. Many of them don't however work for multiscale instruments. fret2find is the best Ive seen.....it calculates things like distances from outer strings to fretboard edge, mid line intersection distances (useful for multiscales) etc. I also like to have a printout of the data so I can tick off each fret as it's cut. As mentioned the only annoying thing with fret2find is the dicking around required if you want a full scale printout of the slot cutting template.
blackalex1952
Post by blackalex1952 » Tue Jan 05, 2016 10:22 am
Thanks for that Martin. Fret2find has been bookmarked!A handy, convenient resource.
Fisherman
Post by Fisherman » Tue Jan 05, 2016 10:01 pm
Almost a pity to hide that beautifully executed joint under the fretboard! At least we all know it's there ;)
Online
Post by kiwigeo » Tue Jan 05, 2016 10:37 pm
Fisherman wrote:Almost a pity to hide that beautifully executed joint under the fretboard! At least we all know it's there ;)
LOL....true. The falcate bracing is pretty too but also hidden from view.
Post by Nick » Wed Jan 06, 2016 5:49 am
Don't usually make 'new years resolutions' but I must get around to reading "the books" this year :oops: (they've been sitting in their boxes for far too long!), that's a beautiful looking joint and stronger that a brick outhouse by the looks. Have you only just removed the sealing layer of Shellac or do you actually change the geometry of the soundboard in the fingerboard area?
Love your work by the way :wink:
Online
Post by kiwigeo » Wed Jan 06, 2016 9:33 am
Nick wrote:Don't usually make 'new years resolutions' but I must get around to reading "the books" this year :oops: (they've been sitting in their boxes for far too long!), that's a beautiful looking joint and stronger that a brick outhouse by the looks. Have you only just removed the sealing layer of Shellac or do you actually change the geometry of the soundboard in the fingerboard area?
Thanks for the compliments Nick (and others). The upper bout is flat and slightly inclined so that a straight rule laid along the neck skims the top at saddle position by 2.5mm. This does away with the fretboard kink at the body/neck join you see on alot of guitars.
Online
Post by kiwigeo » Mon Jan 18, 2016 6:52 pm
Fretboard has been glued on, the neck has been shaped and the heel cap is glued up and ready to go on. Not much left to do structurally on this buiild.
Online
Post by kiwigeo » Sun Jan 24, 2016 9:01 pm
Got the heel cap on. Neck and headstock shaped and fine tuning to the neck body fit. Drilled the tuner holes and the tuners have been test fitted to check straight pull string runs. A bit of fine sanding of the neck and then it's onto preparation for finishing.
collinsguitar
Post by collinsguitar » Sun Jun 26, 2016 12:57 am
Beautiful work. So how did the guitar turn out in the end?
Michael
needsmorecowbel
Post by needsmorecowbel » Sun Jun 26, 2016 9:35 am
bloody hell that join around the bolt down tenon...Awesome work Martin!
Stu
Online
Post by kiwigeo » Sun Jun 26, 2016 9:47 am
collinsguitar wrote:Beautiful work. So how did the guitar turn out in the end?
Michael
Still working on this one Michael. Currently french polishing and working on calculations for nut and saddle compensation. Progress has been slow due to the challenges presented by a multiscale instrument and I was away for over a month at work.
Online
Post by kiwigeo » Sun Jun 26, 2016 9:48 am
needsmorecowbel wrote:bloody hell that join around the bolt down tenon...Awesome work Martin!
Stu
Thanks Stu,
It's nice when something DOES go well :shock:
Online
Post by kiwigeo » Sun Jul 03, 2016 8:57 pm
A few up date pics. Currently french polishing and working on a jig to make up the compensated nut.
Post by Mark McLean » Sun Jul 03, 2016 9:28 pm
Nice looking FP result so far Martin.
Jeez - I hope it sounds good after all of this effort.
Online
Post by kiwigeo » Sun Jul 03, 2016 9:46 pm
Mark McLean wrote:Nice looking FP result so far Martin.
Yeah the thought that's always in the back of a builder's mind :?
routout
Post by routout » Mon Jul 04, 2016 2:24 pm
Youl be rite ,it's looking pretty Swish. :D
Online
Post by kiwigeo » Sun Jul 24, 2016 4:26 pm
Finally got started with French Polishing on the top....light at the end of the tunnel for this build. There's a little bit of lint sticking to the finish around the sound hole.....I changed to walnut oil as a lubricant and this problem has disappeared.
Users browsing this forum: No registered users and 98 guests
