segmented rosette tutorial.......
martinedwards
Post by martinedwards » Fri Oct 05, 2007 2:11 am
OK gang, here's how to make a segmented rosette......
this is for a guitar shaped mandola I'm mking for a guy in England.
Cut a donut of solid wood and cut two grooves to match on the top.
route the gap between the cuts on the top
yup, as thin as this!!!
Cut a contrasting donut.. these are maple and walnut
Mark them in 12 equal segments. NUMBER them!!!
Chop them up.
assemble the bits. there will be gaps because of the thickness of the saw.
purlfing on the outside
and then in all the gaps too.
once it's all glued in I'll cut another slot inside for another purfling strip. then I'll cut the soundhole
Sorry I'm not from the Southern Hemisphere.....
I have an aunt in New Zealand and another in South Africa, can I still play?
BillyT
Post by BillyT » Fri Oct 05, 2007 5:51 am
That's great Martin! How lond did it take you to get that far?
Ron Wisdom
Post by Ron Wisdom » Fri Oct 05, 2007 7:46 am
Thanks, Martin. Be sure to post a finished photo.
Ron
martinedwards
Post by martinedwards » Fri Oct 05, 2007 7:59 pm
BillyT wrote:That's great Martin! How lond did it take you to get that far?
all in those pics about 90 minutes
glue & dry then another circular cut & the inner ring fitted, another 10 mins.......
martinedwards
Post by martinedwards » Sat Oct 06, 2007 1:06 am
Not totally happy with the close up outcome. the outer an inner rings aren't as.... well..... circular as I want,
so I'll re-do the process when my engleman arrives........
Ah well, so who's perfect?
lucky I have the other 12 segments in an envelope, all numbered, ready for use!!
Serge
Post by Serge » Mon Oct 08, 2007 3:30 am
That will be fixed by you in no time Martin, great tutorial mate, thanks! :D
martinedwards
Post by martinedwards » Wed Oct 10, 2007 1:34 am
Ah go on then Serge, here's another attempt at the outer & inner rings.....
I re-cut the grooves and filled them with a wider bwbw strip
still to be sanded out.........
Serge
Post by Serge » Wed Oct 10, 2007 5:14 am
Oh Yeah, hun hun!!! :cl :cl :cl
Serge
