Neck bolts
Neck bolts
Just wondering if anyone that does bolt-on mortise and tenon necks can shed any light on where they get their bolts from...?
I've seen the ones on the LMII site which look pretty good ..
Is there anywhere else I could look.
Cheers Grant
Cheers Grant
I've used both barrels and inserts. I prefer the barrels myself. On the 2 current works in progress I'm trying hanger bolts. They're the ones with wood screw thread 1/2 way and regular machine thread the other 1/2. I'm using a butt joint on the neck, and it seems to be the easiest one to get to fit just so, (at least for me).
James...I think your right ...should be plenty of fastener/cabinet maker supplies that would have this sought of thing.
Allen...I'm interested in the Butt Join method...certainly make things easier I'd imagine....have you heard the guitars yet? I'd be interested to know what you think of the sound compared to M&T necks.
and for anyone interested I googled around and found these.
http://www.timbecon.com.au/products/kno ... 433_0.aspx
They're not complete as yet, but I really can't see that you will notice a difference in tone if the neck to body contact is good. There are quite a few people using a butt joint. I read about it first on the OLF.
I switched to it because my necks are fully bolt on (no gluing on a fret board) and I use a tongue under the fret board that is mortised into a neck block that is a bit like a Spanish Heel. Having a mortise/tenon neck along with the fret board support was just too many tenons to get to fit perfectly when I was trying to get the neck set right.
I got the main inspiration after Colin posted some photos of how he goes about building his neck block/neck joint. I've been struggling with neck set with the wide humidity swings we get up here. I'm still wrapping my head around how to go about an adjustable neck, and that is going to be my next project.
