Compound Radius Fretboard Sanding Jig/ Chris Paulick
chris paulick
Post by chris paulick » Mon Jun 25, 2012 10:02 pm
youtu.be/
Lots of rain here! You can hear it in the background. That's not white noise, more like wet noise. :P
Chris
Re: Compound Radius Fretboard Sanding Jig/ Chris Paulick
Post by Dominic » Tue Jun 26, 2012 9:26 am
Nice one Chris. I've been mulling over something similar but have to upgrade my sander first to a longer bed model. Or perhaps I can just extend the arm and use longer belts.
chris paulick
Post by chris paulick » Tue Jun 26, 2012 9:34 am
If I had $850 laying around and room in the shop I'd get a large edge sander and go with the Fox setup. But don't so I had to go this route. :)
Chris
auscab
Post by auscab » Tue Jun 26, 2012 2:31 pm
Looks good Chris.
I'm interested to know where do I get to see the Fox set up you mentioned?
I just bought a large edge sander and would like to know how its done that way as well.
chris paulick
Post by chris paulick » Tue Jun 26, 2012 7:59 pm
Chris
Phil Mailloux
Post by Phil Mailloux » Thu Jun 28, 2012 8:33 pm
auscab wrote:Looks good Chris.
There's also the old lmii jig, i built myself one a couple of years back out of t-slot extruded aluminium, I adjusted mine to make it usable with compound fretboards, cost me about $250 of parts, a lot cheaper than the Grizzly version, and that one is not adjustable as much as mine. You do a compound radius by adjusting the height differently on both sides
Here's pics in action, you can see how low the bars are on this one, that was a 7.25" radius
OzBassForum.com
MaillouxBasses.com
auscab
Post by auscab » Fri Jun 29, 2012 12:14 am
Thanks Chris, that's a good thread.
Phil, nice one as well. Where do you get that type of Aluminium extrusion?
And what's the hinged bit of wood dragging on the belt for?
Phil Mailloux
Post by Phil Mailloux » Fri Jun 29, 2012 5:03 am
Its for clamping angled headstock necks, there's quite a few makers of these extrusions, 8020 is the most famous brand, Bosch-Rexroth and some others make it too. I bought mine here
http://www.amesystem.com.au
Check out their 'profile system' link to see all the bits and bobs available, they're priced really well compared to the sturdier 8020 brand who's a lot more exy. I already had expenrience with these guys before i build the jig as I used the same compnents to build my CNC a year or so before that. I pretty much designed the sanding jig and ordered the pieces pre-cut to lenght, all that was left when it got here was to drill and tap holes in the locations needed, a nice afternoon project and an invaluable tool for guitar building.
OzBassForum.com
MaillouxBasses.com
chris paulick
Post by chris paulick » Fri Jun 29, 2012 10:33 am
Phil, is that an inverted pin router in the back?
Chris
Phil Mailloux
Post by Phil Mailloux » Fri Jun 29, 2012 10:54 am
Yes it is, its been sitting there unused for some months now since I haven't gotten 3 phase connected yet :roll:
OzBassForum.com
MaillouxBasses.com
