Made with the typical precision of a swiss watch Markus & with that indexing tool you have it even sounds like one
Yes, when cutting 4 or 6 mm per pass it isn't really silent anymore (not suited to work after midnight without running the risk that my neighbours would recommend me some remedies against snoring). Although, slowing down the cut reduces noise and the cutting quality will remain the same. Also, cutting only 2mm per pass makes a really silent job.Clancy wrote:Streeewth!![]()
Oh, I chose the wrong soundtrack...Kim wrote:The Acid Queen kerfing machine is nothing short of a work of art [...]
Lillian wrote:Brilliant! Just bloody brilliant.
Thanks. Yes, I am glad it works. I wouldn't know what to do with it if it didn't work. I would have to pay for dumping 12 kg of an assembled mix of wood and metal scraps.Kim wrote: [...]and you demonstrated a great number of skill sets in bringing it from and idea, to a fully functional thing of beauty![]()
Watching Luca Waldner's method for cutting regular kerfs in the linings was really a revealing moment for me. Just too simple to be true. Though, his apparatus was better designed than mine. Waldner uses a dremel-sized small circular saw which gets swung over the lining, so the remaining web, regardless of the thickness of the lining will be of a constant thickness. O course, this can also be achieved with a smart setup of a backsaw with a depth stop, where the latter does not stop against the lining itself but a miniature mitre box. The advancing system could remain the same. To have the pictures of the advancing gizmo also here in the forum (and not only 5 seconds each in the YouTube video) I'm posting them here once again.charangohabsburg wrote:A surrealistic - meditative journey along a kerfed lining:
[...]Markus on YouTube wrote: [...]
The gizmo for feeding the lining I made after an idea I have from the Italian world class luthier Luca Waldner ( www.lucawaldner.com), back in the times when he had the guts to run an own Internet forum and had some really useful hints online.
Users browsing this forum: No registered users and 23 guests
