Measurements On Dark Woods
Post by ozziebluesman » Tue Dec 23, 2008 12:04 am
Just finished a Ukulele fingerboard made from Indian Rosewood and while cutting the slots I missed a marked measurement by a mm. Damm!!! It is on the 18th fret so I am not too concerned. Except I know it's a mistake and I hate that!
So what do you all use to mark out darker woods to make it easier to see the measurements? Pencil is just too hard to see unless you have exceptionally good light!
Post by Lillian » Tue Dec 23, 2008 12:28 am
Yellow pencil works best for me. Or you can make the mark with a awl or marking knife and then go over the mark with chalk. Wipe away the excess and the chalk will stay in the grove or hole.
Post by jeffhigh » Tue Dec 23, 2008 5:51 am
For marking out fretboard slots I use wfret to print a paper template, check the distance to the 12th fret (for printer error) and adjust scale input if needed
I then lightly glue it to the centre of the fretboard, mark through the paper into the board with an awl and pull off the paper.
I cut with a handsaw in a mitrebox and find that the awlmark is great to line up the saw on. Chalk like Lillian suggests would be great.
Post by sebastiaan56 » Tue Dec 23, 2008 5:53 am
I believe Allen did a tute here viewtopic.php?t=603
Post by Allen » Tue Dec 23, 2008 6:47 am
I've got your disease too Alan. I will use a white pencil to mark the spacing. Double check. It's dead easy to get the spacing wrong, so I find that marking them out with the white pencil and then standing back for a look will show if something is off very quickly.
Then I scribe the line with a sharp scalpel and rub in some chalk.
Post by Mark McLean » Tue Dec 23, 2008 6:55 am
I was using a white chinagraph pencil, which leaves good marks but it is hard to get to a fine point, and they are expensive. Since Allen's tutorial I have used the scalpel and chalk trick - very happy.
Post by jeffhigh » Tue Dec 23, 2008 7:09 am
My Awl mark ends up being pretty much the width of the saw blade so it is hard to miss. I just cover it with the saw blade and I am centred.
Measuring and marking each fret position with a steel rule? I am sure I could not do that acurately with my over 50 eyes
Pete Brown
Post by Pete Brown » Tue Dec 23, 2008 10:56 am
Hi all
I picked these ballpoint pens up at the local art supplies store.
The tip is 0.7mm - fine enough for many tasks - and the ink can be removed with a damp cloth.
Post by DarwinStrings » Tue Dec 23, 2008 11:05 am
Hi Peter and welcome
Nice tip, I have used my kids white pencils so far but after your post I am really annoyed with my partner as she has worked in a Art Supply place for 15 years. Hmmmm or should I blame myself for never asking.
Post by Allen » Tue Dec 23, 2008 12:45 pm
Welcome to the forum Peter. Good tip about the pens. I could use them for all kinds of things. Gotta go into town and get me some.
Post by ozziebluesman » Tue Dec 23, 2008 2:43 pm
Thanks everyone for your tips. The awl and the chalk and the white ball point pen are great tips.
Allen, i missed your tutorial. :oops:
Users browsing this forum: No registered users and 174 guests
