New Luthier Tips du Jour video - Top Bracing
- ANZLF Approved Supplier
The latest Luthier Tips du Jour video is on the air. The topic is acoustic guitar top bracing and my glueing sequence.
Comments and discussion are welcome.
Enjoy!
youtu.be/
Enjoy!
youtu.be/
www.obrienguitars.com
- hilo_kawika
The construction sequence is clear and uncomplicated - another job well done, Robbie.
But if you're as confused as I am about the shapes of the braces and the reasons for their shapes, here's a very nice Oz link to some information which might form the basis for a number of future discussions on the forum:
http://www.phys.unsw.edu.au/music/guita ... ladni.html
David
David
Yes Robbie, I am with Lillian 100%.
The time and effort you put into these submissions is very much appreciated, not by those of us on the forums alone who make a point of telling you so, but by many, many people entering this craft who, whilst remaining voiceless behind the anonymity of youtube, would be no less inspired.
I am certain that Chris and Co of LMI are truly counting their blessings for your affiliation with their company rather than their opposition.
Cheers and many thanks.
Another great lesson Robbie. The positioning of the nodes and the general measurements are very useful information. I wasn't sure what to do if I didn't have an explicit set of plans to follow - but this gives me a good rationale for planning my own bracing layout in the future.
BTW, I just posted some photos of my first guitar build, done with an LMI kit and your DVD as guidance. It works!
many thanks
many thanks
- sebastiaan56
Robbie,
This probably a stupid question and maybe I dont understand something but I notice in the video the bottom of the braces are being profiled by rubbing the brace lengthways along the central area of the dished form. This would be ok for a brace that is going in at the top of the 30' arch on the top but for UTB's, tone bars, finger braces etc surely the arch on the guitar top where they sit is not 30'.
Up to now Ive marked out brace locations in pencil on a sand paper lined dish and then shaped braces by placing the brace on the appropriate pencil line and then rubbing it along imaginery axis of top.
Martin, this one seems to come up every so often. Thankfully its answer is in maths. The radius anywhere in a 30ft radius dish is 30ft. It does not change. What you are thinking by keeping your braces vertical as you move away from centre is effectively changing the angle they meet the top as you move away from the centre. If you glue all the braces perpendicular to the top or back at every position (and this also implies keeping your quarter sawn brace wood at its most effective angle, 90 degrees to the top) it does not matter where you sand your braces.
Imagine you are in big beach ball 60 ft high (30ft radius). If you imagine a 500mm circle on the ground you will have the shape of your dish. If you stand there you are at 90 degrees to the floor. Just like a good quarter sawn brace but with a shiny noggin.
If you walked up the wall you would get to the point where you were parallel with the floor (now the wall). More like a flat sawn brace. This is what you are effectively doing to your braces if you sand them pointing straight up at the edge of your dish. Granted it is only marginal and you are likely not to notice. But there is no point going to all the trouble to effectively turn your perfectly quarter sawn brace wood ever so slightly off perfectly quartered. Just do em in the middle.
Users browsing this forum: No registered users and 137 guests
