String spacing question
- Hippety Hop
Are there any standard nut widths, saddle widths, fretboard widths or string spacing at either end?
Not googling too well today.
Cheers Hip.
Cheers Hip.
G'day Hip and welcome.
Depends what sort of guitar.
Here's a link to a spreadsheet that'll give you a lot of information on the standard widths and string spacings for acoustice steel strings.
If you're after Electric or Classical specs I'll see if I can point you in the right direction but the Martin one is all I have.
Most of the electric guitar manufacturers - Fender Gibson etc will have specs on their site.
Martin Specifications
Bob
Bob
- sebastiaan56
- ozziebluesman
G'day Hip,
Buy one of these and save some hassle!
http://www.stewmac.com/shop/Tools/Measu ... _Rule.html
You can have any width you like for a guitar neck. Finger style guitars are usually around the 1 3/4" mark where a dready is a little narrower while the classical is wider at around 2". These are only approximate widths.
- sebastiaan56
Hi Hip,
You can also make a jig for about 1c. On a fresh piece of paper measure out six dots at 3mm apart and then 75mm away measure out six dots at 10mm apart. Join the dots so you six lines fanning apart. Find the place where the lines are equidistant on your nut, saddle, bridge, whatever and mark off from that. Same for three, seven strings. For double courses, measure out double lines. Easy as and keeps the balance of trade a bit more equal.
Love the game of snap guys, Bob wins!
Sebastiaan
Sebastiaan
- graham mcdonald
It is worthwhile considering differing spaces between the strings to allow for the thickness of the string itself. Like a .056 bottom E is five times the thickness of the top e and if you adjust the spacing at the nut so the difference between the edges of the string stays the same it looks a little more elegant I think. Not crucial, but it does make a difference with double strung instruments
graham
graham
Graham McDonald
Yep, I use the SM spacer rule which compensates for string width like Graham suggests. I just use what I think is right. For me I play a lot of finger style so give myself a bit wider nut and i don't mind a bit more space for my picking fingers. So the fingerboard is around 44mm at the nut and 55mm at 12th fret. I also find the low E string is more likely to slip off the fret board, at least with my playing style, so I give a bit more space in from the edge for the low E string than the high E. Then just use the rule to divide up whats left.
All my guitars are slightly different but I am still looking for the perfect neck, string spacing, scale etc etc combination for me. Means I gotta keep making guitars for myself. What a bummer
- Hippety Hop
Thanks for the help fellers. Love the Martin specs. And I also like the idea of taking string thicknesses into account.
I haven't built anything yet. I've got the wood for a uke, but I'm still in the process of scoring/scrounging tools. I assembled a pre-bent-pre-carved kit uke, and brush finished it with shellac. Feels like silk. Sounds nice too. Looks ordinary - pretty ratshit if you look close - even at a glance.
Hey, a mate has given me his bandsaw. I pick it up from Koroit on the weekend after Queen's birthday.
I have a $220 sheet of 19mm marine ply waiting. Well I didn't like the look of the knotty crap they had at Mitre 10 & Bunnings.
Make my own brew. Keg. Grouse.
Cheers Hip.
Cheers Hip.
- MetcalfGuitars
- Gidgee
Hey guys, I have a nut slot spacing spreadsheet (works in MS Excell and OpenOfffice) I developed for my own use. It's simple to use and adaptable for any width nut.
it's free to all if I can just figure out how to post it on the forum. Is there someone that can walk me through posting files to share?
Tim
MetcalfGuitars.com
MetcalfGuitars.com
- Dennis Leahy
- MetcalfGuitars
- Gidgee
Hey Dennis,
My calc is equal spacing between strings. Basically you enter the inside dim between the two outer strings, input the string diameters of the 4 inner strings.....the calc will give you spacing 1 to 2, 1 to 3, 1 to 4 etc. I use it on every guitar.
I've emailed it to Bob so he will post it for all. Enjoy!
Tim
MetcalfGuitars.com
MetcalfGuitars.com
- John Maddison
- MetcalfGuitars
- Gidgee
- John Maddison
- Graham W
- Kauri
String Spacing
G'day Hip, from wintery New Zealand.
I make the width of the fingerboard at the nut to suit the player of the instrument - in my own case I like around 45mm for a steel string. I think you can personalize this measurement without too much worry.
If you're building steel string guitars and plan installing a pick-up under the saddle, keep in mind that many piezo type pick ups are designed to go under a 55mm string spacing at the saddle/bridge. If you go too far outside or inside of 55mm you will find an imbalance in output between the strings when amplified. Some under saddle pick-ups are active along their entire length. It would definitely pay to check the specs of the pick-up before deciding on the saddle string spacing as this will vary from make to make - also it will be wider for nylon/classical guitars.
I hope this is of some help. Good luck with your project.
Graham W
Graham W
Graham Wardrop
PO Box 18 845
Christchurch 8641
New Zealand
guit.art@clear.net.nz
PO Box 18 845
Christchurch 8641
New Zealand
