to seal or not to seal
- rocket
In the past i haven't sealed the binding rebate with a coat of shellac prior to glueing in the binding, whether using timber or pvc, not because i didn't deem it necessary i just didn't think of it, and as yet i've been lucky i suppose, had no bleeding of natural colour from the binding into the back or top.
I've got a pure blonde build on the go with Jarrah binding and thinking that to be on the safe side i'd seal the rebate especially on the spruce top just incase it decides to bleed.
Any thoughts on this? in regards to necessity, sealing methods,and the use of Titebond in the sealed rebate.
Cheers,,
Cheers,,
Re: to seal or not to seal
Rod,
I've never sealed my binding channels but from reading around the shellac doesnt seem to interfere with the Titebond glue joint.
- steve roberts
Hi Rod
I don't seal rebates either because I don't like to do anything that may affect my glue surfaces. I did a build last year and used jarah bindings and I had no problems - but it is always beter to be safe than sorry!
Regards Steve
Regards Steve
My "Shed" guitar has Jarrah binding directly onto a radiata pine top and light red meranti sides. Glued straight on with Titebond Original, no pre-sealing, no top purfling, no issues.
- 56nortondomy
I always seal the the purflings and binding, but not the channel, i've had no issues so far. Wayne
- rocket
Thanks for all the input there,, i think i'll proceed as normal.... unsealed rebate. This build has has a Jarrah lamination running down the centre of the back and neck and when laminated the blanks i didn't detect any signs of bleed on either and the laminations and bindings are cut from the same billet so i think i'm pretty safe.
Cheers,,
Cheers,,
I always seal or rather size the rebates with HHG. Works every time.
Ive used jarrah a couple of times for binding and centre strips in necks and never had an issue with bleeding ,
but this thread interests me as I have just used a red veneer in a headstock and although it didnt bleed into the other woods it was only luck that it was sandwiched between a couple of fairly dark woods I think that saved the issue as the titebond turned "pink"
I want to use a red purfling in the top basically W-B-R up against the sitka top ,will shellacing the binding channel stop it bleeding or should I shellac the purfling as well before I glue it ,I usually use CF for my bindings,and I know shellac is compatible with most finishes but is it the same with glues ?
