What material would you recommend for making the side mass weights?
Side mass
- woodrat
Re: Side mass
Hi Scott, I believe that Trevor used mild steel. I use Brass because I have some 1 1/2 x 1/8 inch Brass strip thats a pretty useful size and avaiable.
Re: Side mass
Thanks, Is brass as heavy as mild steel? I'd bet the brass is easier to drill!
My excuse is "I'm new"
- woodrat
Re: Side mass
Google specific gravity of brass and then Google SG of steel
Re: Side mass
Brass is made up of Copper & Zinc Scott, Copper is reasonably heavy & Zinc is deceivingly heavy!ScottC. wrote:Surprising:
Brass= 534 lbs. per cf
Steel= 495 lbs. per cf
Re: Side mass
Yes, I use steel, but anything cheap and dense can be used. That should leave plenty of opportunity for the wits around here...
Users browsing this forum: No registered users and 159 guests
