The Celtic Beauty - The epic journey
Rod True
Siberian Tiger
Post by Rod True » Wed Dec 01, 2010 11:44 am
Well, I sort of don’t know where to start with this one. It’s been a very long time in the making for me. Now please remember that I'm just learning this craft. This was to be guitar #5 for me, but after all this it turned out be #8.
This is a long story and worth writing if you don’t mind reading about it. If you do, scroll down to the pictures, hope those will be of interest.
OK, Back in December 2005, Bob “The Zootman” Cefalu posts pictures on the OLF of some incredible Imbuia, I jumped on the email and told Bob I wanted that wood.
It sat in my shop for 5 months when a friend of mine asked me if I would make a guitar for her. This was late spring 2006. I said I’d be happy to and that I had a rather special set of wood that she might like. So I showed her the Imbuia and she really liked it. She’s of Scottish heritage and she wanted a Celtic sounding guitar.? So I thought that we would couple the Imbuia with Cedar, a nice warm sounding guitar I though. She also wanted lots of Celtic inlays on the guitar.
So, I got to work on the guitar, started it in June 2006. I was in for a journey. Here’s the way this guitar went before I finished it this past week.
Started by wanting to make the rims. I was using a light bulb bender at the time and it worked great for EIR but that’s all I’d ever worked with before. Well, the Imbuia was totally different. I broke the first set of sides while trying to bend. I called up Bob and he sent me another set of wood and I started to sand them. When sanding, one of the pieces hopped up from my push board and shot back at the handle and broke into 50 pieces or so. ”Bob, do you have another set of Imbuia sides, I broke another piece.” Yes, Bob had another set and sent them to me.
I now built a new side bender, got a heating blanket and spring steel slats. The sides bent wonderfully. I got the cutaway bent and assembled the rims. This was now in the Summer of 2006.
I got the back thicknessed and braced up with no issues and it was ready to attach to the rims, I wanted to get the top ready to attach to the rims too, so I started working on the rosette. That was a nightmare for me. First I inlayed the Gold MOP Celtic rosette upside down. I didn’t know that the Gold doesn’t go through the shell all the way, and when I had finished, I had a white MOP Celtic rosette instead of a gold one. I pulled all the pieces out and started to inlay them by hand, piece by piece into the top. It turned out ok till I tried filling it with black epoxy. It was a nightmare again, smearing black epoxy over the top and everywhere. AGH! I started to sand down the rosette and well, I sanded through much of the gold shell to the while pearl and the top was getting thin with still a bunch of black epoxy on the Cedar and the rosette looked like crap. That top hit the floor and I ordered another rosette. This time, I inlayed the rosette into the new top correctly. I didn't try epoxy this time but tried ebony dust and CA. Well that was a total nightmare. In order to fill all those cavities... let me just say that I didn’t do it right and I used to much Ca and it started to get the top hot and it actually warped the top. When the CA cured I started sanding down the dust/CA filler and due to the warping of the top, I sanded the upper bout way to thin and I was getting really frustrated thinking I’d never get this thing right. That top hit the floor and I ordered another rosette.
I now put this guitar aside, feeling like I was biting off way more than I could chew.
Came back to the guitar in early 2007. Now that the back had gone through a few seasons with some humidity changes, it had flattened out a bit so I pulled the braces off and waited till I was ready to brace up the top.
Take 3 on the rosette went great. I got some advice from another builder, who had inlayed the same type of rosette on one of his guitars. It all worked out fine and I could finally brace up the top and get it on the rims. I think we are just into 2007 at this point.
I had a new idea in my mind for a bracing pattern. So I set to work getting this done. Voiced and ready to attach to the rims, I braced up the back and got it glued to the rims. It was a box finally.
I took a rather long break from the shop in late spring of 2007, actually it was a nine month break due a very difficult pregnancy my wife (and I and our other kids) went through. Shop time came to a full stop. I didn’t get back at this guitar till spring of 2008.
I started to work on the bindings, bending Ebony is not very fun. I broke a few sets but the really hard part was the cutaway. I must have broken 5-6 pieces just tring to get it bent. Finally I decided to use black fibre 0.020” thick, stacked up on the cutaway. It worked pretty good to my surprise.
OK, so now I got the body all done, onto the neck. A few other life moments keep me out of the shop again and I found myself putting this guitar on hold, again!
I got back to it in late 2008 or early 2009. I got the headstock inlay done and then the neck sat again. I finished off a guitar for a friend of mine while I pondered how I was going to inlay the “Trinity” knots on the fret board. This took me to spring of 2009, when I lost my job and ventured out on starting my own company. There goes the motivation to get into the shop. I was so exhausted with my day job that I had no motivation to go out to the shop.
Finally, winter of 2009/2010 I got motivated enough to get the fret board inlayed and then the neck come together rather quickly. I found myself ready to finish the guitar in mid February 2010. As I was spraying shellac seal coat on the body, I dropped the body and it hit the floor and fractured the top and binding at the lower bout. I cut out the fractured portion of the top and I inlayed another piece of cedar from the off cut of the board. It was a seamless repair but I could still see a slight difference in the wood color. This guitar was killing me. I just had to get it done. So I sprayed it and waited to buff it out, than attach the neck. This was April 2010.
I attached the neck, got the bridge located and attached it, I installed the frets, levelled and polished and it was ready for a saddle and nut. I had a friend over the night I was stringing it up for the first time.
Now remember, I had tried a new bracing layout. It was braced really lightly and I found out very quickly after the strings went on that it was just way to lightly braced. With the strings on, up to concert pitch, the top rose, and rose and the bridge rolled forward and forward and even separated from the top just at the back of the belly.
This was total top failure. It happened over a period of about 1 hour.
So, instead of smashing the guitar into 100 pieces right then and there, I set it aside for a month. Then I removed the top (#3) and cut the rosette out, which I needed to salvage for the next new top.
I got to work on top #4, getting down in my stash of cedar now. I got the rosette inlayed. I braced the top as I had done on my other guitars.
I got the top glued back on the rims, bindings bent, dang, I had another piece of ebony to try for the cutaway. I actually tried again but to no avail, I couldn’t bend that ebony for the cutaway. I broke 3 more pieces. So, I bent a piece of EIR and after installing it and levelling it, I died it black with Indian ink.
So now I’m back to the finishing stage, this is now October 2010.
Into the booth, spray spray spray.... then the wait. Level sanded and used my buffer for the first time (everything before this was hand buffed)
Got the neck and bridge glued on just a couple weeks ago and I let it sit for 3 days before I could get strings on it.
I was now at the home stretch, rounding third, I could see the summit...I put the nut and saddle in place, put the tuners back in place and got out a set of strings.....
HOLY COW was I ever nervous. After all this, I was again putting strings on this guitar. Would it survive? Would it sound ok? I was pretty confident in the bracing that I did as I have several other guitars with the same bracing and they are all holding up just fine. But I was still nervous.
Moment of truth. Stings went on, pulled up to concert pitch and beyond the normal popping and creaking, everything was fine. The top hardly moved. So, I let it sit with high action, a flat saddle etc for 3 days. Of course I played it and the sound started to open up (gotta love Cedar for this) and I was thinking it might be my best sounding guitar yet.
So, this past Tuesday, November 23, I did the final set up on it. Got the action nice and low as I my customer wanted, got the intonation all dialled in and did a final polish.
My wife took pictures of the guitar this morning and at 8pm tonight, I delivered the guitar to my friend.
What an amazing journey of trial, stupidity (on my part) and perseverance. I totally love this guitar and want to build another one right away. But I hope I never go through these types of challenges again.
Thanks for sticking with me on this. Now onto the pictures, there aren’t many but they are good :D
Re: The Celtic Beauty - The epic journey
Post by DarwinStrings » Wed Dec 01, 2010 12:59 pm
Rod True wrote:So, instead of smashing the guitar into 100 pieces right then and there, I set it aside for a month.
A great bit of restraint shown there Rod. I am glad that the guitar finally managed to put a more than satisfied smile on your face and I guess you don't need me to tell you that it is a work of great beauty. Excellent inlay and rosette execution as well as design. Well done.
Post by Lillian » Wed Dec 01, 2010 1:34 pm
Rod, it might have been long in coming and fraught with problems, but all I can say is (cue Billy Crystal) It looooooks Marvelous!
Good on you for having the strength to step away from it when you needed to.
Post by Nick » Wed Dec 01, 2010 1:43 pm
An absolutely beautiful piece of work Rod & well worth the trials & tribulations. Not only has the customer ended up with a thing of beauty but you learnt several lessons from it without it ending up getting fed to the bandsaw! Can't ask for any more than that IMO.
seeaxe
Post by seeaxe » Wed Dec 01, 2010 5:55 pm
Rod,
As we say in this neck of the woods, you poor b*****d!
On the upside, I now feel a lot better about my somewhat similar experience, as it pales into insignificance compared to that lot. (Incidentally, it was my fifth one too - spooky!)
In the end, you (and us of course) will be the only one that will ever know - as you cannot tell by looking at it, it looks stunning, love the back and sides wood.
I am sure the recipient will love it too.
Lets hope the next one is not so eventful.
J.F. Custom
Post by J.F. Custom » Wed Dec 01, 2010 9:28 pm
Wow Rod. What a story and what a fitting finale'.
That's a beautiful result worthy of your commitment and effort. You truly never know the history of a guitar from face value and as mentioned, no-one else would guess at the angst is has caused. What a steep learning curve luthiery work can be... The trials and tribulations, and yet, we keep going back for more. Masochism?
Nah. 8)
Post by Bob Connor » Wed Dec 01, 2010 9:28 pm
It's come up a treat Rod. A real tribute to your determination and patience. I hope you never have to go through that again but seeing the end result must make you glad that you perservered.
Rod True
Siberian Tiger
Post by Rod True » Thu Dec 02, 2010 6:55 am
Thank you all for your kind comments. If I can in someway be an inspiration to anyone else struggling with a guitar that just doesn't want to be built, I'm glad to help.
We all have these ideas in our head. Sometimes they work out and sometimes they don't. I'm just glad this one worked out, cause it cost me a freekin tub full!!!! LOL
Needless to say, there was a lot of :gui :gui :gui :gui :gui in celebration :D
P Bill
Post by P Bill » Thu Dec 02, 2010 8:26 am
It's a real beauty Rod. A great story. As some of our politicians have said have said "....crash through or crash ."
Post by ozziebluesman » Thu Dec 02, 2010 9:36 am
Lovely guitar Rod! The story was a great read too. Just makes me feel good to see someone else suffer these setbacks and be able to bounce back by building a superior instrument. Where there is a will, there is a way! Thanks for the post, I enjoyed everything about it.
Post by Taffy Evans » Thu Dec 02, 2010 7:43 pm
I'm in late and its nearly all been said, but I agree with every bodies comments.
As I say to my mates on a long motor cycle ride, its not how quick I get there its the journey that counts.
Dave Anderson
Post by Dave Anderson » Fri Dec 03, 2010 12:17 pm
Wow,what a journey on this one Rod. CONGRATULATIONS for hangin' in and finishing it !That took
so much patience and sticktoitiveness!(could that be a word?)
It's a very beautiful guitar. I'd love to hear it....
Dave Anderson
Port Richey,Florida
Crafty Fox
Post by Crafty Fox » Thu Apr 28, 2011 10:07 pm
Just come across your posting. I really love that guitar! And the build story. I think with your "Never-Give-Up" attitude you should be granted Honorary Australian citizenship! And since I'm originally Scottish I should have a "Celtic Beauty" too. Or would it be easier if I just married your friend? I'm on my 8th build now and my #5 was a pig too. Great neck, but crap sound and poor finish.
Many thanks for your posts, I'm inspired. :cl
Ken
Ron Wisdom
Post by Ron Wisdom » Fri Apr 29, 2011 6:13 am
Rod, that really came out nice!! The rosette looks great. Beautiful guitar and a nice tale to go along with it. Glad it worked out.
Ron
Tod Gilding
Post by Tod Gilding » Mon May 02, 2011 8:23 pm
That's a magnificent effort and story :cl
And You have very patient friends :D
pat foster
Post by pat foster » Mon May 02, 2011 11:50 pm
Rod,
I don't post here much, just manage to drop in once in a while. I just came across your thread. Great story, great guitar!
Pat
P. S. Ron Wisdom, there's a flash from the past. Good to see your post!
Ron Wisdom
Post by Ron Wisdom » Tue May 03, 2011 4:34 am
You too, Pat. I check in pretty regularly but haven't had a lot to say lately.
Ron
