Graphite Required Urgently (A Graphite Discussion ;-)
Post by Kim » Tue Apr 21, 2009 9:13 pm
Folks,
I have a project on and need some graphite sheet stock suitable to laminate between spruce for braces ASAP, .020" is good .030"is better. I only need 1 bit about 300mm long x 1/2". If anyone has some local they would be willing to part with I will pay cash and postage or replace what ever is sent as I will be placing an order with Jim Watts @ Los Alamos Composites shortly http://www.jameswattsguitars.com/LAC.htm
I know Jim will ship pronto if I ask but I really would prefer not wait for shipping from USA if someone has some sitting spare here in AU.
John Maddison
Post by John Maddison » Tue Apr 21, 2009 10:19 pm
G'day Kim
have got two long sheets here of .020" that David Hurd brought over during Playmakers; 75mm wide, can spare you a 300mm strip; swap for something down the track ... send PM with address if interested.
Happy Easter & all that!
John M
John Maddison
Post by John Maddison » Tue Apr 21, 2009 10:40 pm
David H's supplier is The Composites Store
Any cheaper?
John M
Post by Kim » Tue Apr 21, 2009 10:47 pm
Brilliant!! Thanks John, PM on the way 8)
Post by kiwigeo » Tue Apr 21, 2009 11:04 pm
Nice one John.....ANZLFers helping each other out, thats what its all about.
Re: Graphite Required Urgently
Post by kiwigeo » Tue Apr 21, 2009 11:14 pm
Kim wrote:Folks,
Kim, I woudnt mind seeing a tutorial at some stage on how you make up those braces.
Cheers Martin
Post by Kim » Tue Apr 21, 2009 11:53 pm
I will only be doing the one brace on a beater Martin but will be taking some images this time round as in the end it certainly will be a different guitar to what I started out with.
Many thanks again to John, this is indeed what the ANZLF is all about, AU was a lonely place to be lute'in before this forum started up.
Dennis Leahy
Post by Dennis Leahy » Wed Apr 22, 2009 12:09 am
John, thanks for the link to the Composites Store. I had a look around the site...
Kim, I'm guessing this would be for composite bracing, which is something I have started to investigate.
This may not be a great place (in your "urgently needed" thread) to discuss this, but it appears that there are at least three variations on how carbon fibers are laid up in sheet form: unidirectional, each layer at 90°, and each layer at 45°. Some seem to be designed to handle shear (and possibly compression) loads (unidirectional fibers.) I would think that for something like a rectangular rod to go into a neck to prevent bowing, that the ideal would be to use material that was not unidirectional, to provide maximum stiffness and not even worry about shear or compression.
And that leads me to the thin sheet used in a sandwich in braces. Different luthiers may have different engineering ideas about CF laminated braces, but for me, the ideal would be a brace that was shaped into a 25 foot radius would permanently hold that radius. So, I would think the least unidirectional fibers the better, so that the 45° web design in John's link should outperform the 90° fibers in this carbon plate (half of which would be unidirectional.)
I note that Los Alamos Composites mentions on their site that their products (rod and sheet) employ all unidirectional fibers. Again, to me, that does not seem ideal for neck reinforcement, so it must be true that when enough unidirectional fibers are laid up (actually, I think the fibers are unidirectional because they are extruded/'pultruded' and are not really laid-up), the rods get plenty stiff enough to do the job. But, wouldn't the ideal be bias web sheets, cut into rectangular rods?
Sorry if this seems rambling, but I do think that at least theoretically, the bias web designed sheets that John linked to make the most sense to me, as the CF I would want in laminated braces.
Thanks, John! And David Hurd!
Another damn Yank!
John Maddison
Post by John Maddison » Wed Apr 22, 2009 12:32 am
Very good research, Dennis! Am eternally indebted to David Hurd for his knowing.
John M
hilo_kawika
Post by hilo_kawika » Wed Apr 22, 2009 12:46 am
Aloha Dennis,
I'm a big fan of the 45 degree layed up sheets for bridge plates. I think I had a brief tutorial about it here somewhere. And I agree that using it flat or on edge would be quite useful - especially on edge where the fibers would always be in tension. And the folks at the composites store have always been good to deal with as well.
When I built my 18' long fishing boat using the stitch-n-glue method I used a triple overlap of biaxial woven roving on each seam inside and out for the same reason - fibers would always be in tension during any possible flexing. The boat's pretty stiff I must say. Here I am at the helm with a friend along for fishing yesterday:
aloha,
Dave Hurd
http://www.ukuleles.com
John Maddison
Post by John Maddison » Wed Apr 22, 2009 12:50 am
Aw, c'mon David,
Enough fish!, get back to building fabulous ukes! :?
John M
Post by jeffhigh » Wed Apr 22, 2009 7:22 am
Kim,
I have a length of 12mm x2mm that I could cut you off 300mm no problems
Let me know.
Mike Thomas
Post by Mike Thomas » Wed Apr 22, 2009 10:06 am
Dennis, as I understand it, unidirectional carbon provides maximum resistance to bending along its length i.e. a carbon rod used as neck reinforcement needs to be unidirectional since the main force being countered is the tension of the strings. And because carbon works most effectively in tension. the rod needs to be inset into the neck as far away from the strings as possible i.e inset as deeply as possible. If however the force to be resisted is torsional i.e. a twisting force, then 45 degree woven carbon is what you need. Or even better two layers of unidirectional carbon laminated at 45 degrees to each other.
Mike Thomas
Post by Kim » Wed Apr 22, 2009 12:37 pm
jeffhigh wrote:Kim,
Let me know.
Most kind of you to offer Jeff however I believe John already has some .020" in the mail which should do the trick. I will use two layers as part of a 5 ply layup. The 2mm would have been very good though and I really do appreciate your most generous offer.
Must confess that I did not give too much thought to unidirectional v 45° woven and orientation, I just need a very strong upper transverse brace on this one because it will be required to support the butt end of a heelless neck which will be let into the brace by about 3mm (yes I know? but that's just how it is this time :lol: )
Anyhow, thanks everyone for the input and please do continue this conversation re unidirectional v 45° web. The more clarity the better so please feel free to elaborate if you have thoughts or experience with CF.
Post by jeffhigh » Wed Apr 22, 2009 2:03 pm
Kim , in the situation you are describing I would do a horizontal lamination rather than vertical for strength.
From guitar top inwards
3mm spruce ( to accomodate the neck inset)
CF (full width not notched
12mm spruce
CF full width
A capped brace is much stronger than a vertically laminated one for the same volume.
James Mc
Post by James Mc » Wed Apr 22, 2009 8:35 pm
Hi All
I'm not sure how the price stacks up with having CF sent from the US (seems to me that US postage charges have gone up lately), but I recently got a couple of lengths of 5mm solid CF rod from a Brisbane supplier. A 1m length was $15.75 and while they don't have a huge range, they have a number of shapes and sizes that may be of use in guitar building.
This is the link to the CF on their site, also worth checking out their other stuff if you are after bearings or CA glue http://www.hobbyparts.com.au/store/cate ... bon+fibre/
James
hilo_kawika
Post by hilo_kawika » Thu Apr 23, 2009 1:39 am
It's often useful to actually do simple deflection or vibration testing of the CF material to determine how stiff the material really is. When I started using CF in ukulele necks about 8-9 years ago I'd ask suppliers how stiff their CF was. Usually the answer was something like: " Wow, man, I mean like it's reely, reely, stiff man".
Deflection testing on my part usually came up with a number on the order of 10 million psi, clearly not space station grade which I believe is ~6-8 times higher. In any case it turns out that regular aluminum bar has the same stiffness and is only a little more dense.
I'm not suggesting that aluminum be used in brace lamination situations, but it may well be useful for neck stiffening, at least for ukuleles. Simple testing procedures will allow you to make such decisions in a more rational manner.
aloha,
Dave Hurd
Dennis Leahy
Post by Dennis Leahy » Thu Apr 23, 2009 2:10 am
hilo_kawika wrote:... it turns out that regular aluminum bar has the same stiffness and is only a little more dense.
...aluminum ... may well be useful for neck stiffening, at least for ukuleles.
aloha,
Dave Hurd
Hi David,
Will aluminum eventually take on a "memory" of the bend, and thus lose some of the desired characteristic? CF has a reputation (I don't know if it is justified or mythical) to return completely to the original shape after deflection.
Just wondering aloud.
Another damn Yank!
hilo_kawika
Post by hilo_kawika » Thu Apr 23, 2009 10:20 am
Hi Dennis,
I think you've asked a great question. Here's a reference to a brief article dealing with metal creep as a function of temperature:
http://www.tech.plym.ac.uk/sme/mats340/cpintro.pdf
Aluminum Melting Point: 660.37 °C (933.52 K, 1220.666 °F), so from the article 0.5 x melting point ( K ) would give ~165-170 °C - somewhat hotter than I would like to have a guitar or ukulele neck. So I think aluminum would be o.k. with respect to creep issues at least for the practical lifetime of the instrument and the stresses involved. Ah, for access to a materials testing lab...
aloha,
Dave Hurd
Dennis Leahy
Post by Dennis Leahy » Thu Apr 23, 2009 10:59 am
hilo_kawika wrote:Hi Dennis,
aloha,
Dave Hurd
Yeah, but if I play Superman, and simply take the rectangular rod in my mighty hands, it will bend (without even using my heat vision.) And, once I let go, it might spring back a bit, but I'd never get it straight again. That's the kind of memory I'm speaking about.
Another damn Yank!
Post by jeffhigh » Thu Apr 23, 2009 3:55 pm
Dennis,
Aly's aint Aly's depends what it is alloyed with and can give huge increases in strength over plan aluminium.
Been a while since I worked as an engineer and steel was more familiar to me but I will try to explain.
Most metals, including steel and aluminium have both a yeild strength(or elastic limit) and an ultimate tensile strength (where it breaks)
This is a separate property to it's stiffness which is how much it deflects for a given load.
Deflect an object within it's elastic limit and it will return to original. Deflect it past this point and it will deform permanantly.
Steel and aluminium generally have a large gap between yeild and failure which I suspect CF does not.
In your example you have taken the aluminium bar past its yeild point so it has permanantly deformed. To get it to that point though you have probably deflected it much more than would ever be acheived in service ( if designed properly)
I
Post by Allen » Thu Apr 23, 2009 5:45 pm
So, this is why some of the instrument plans that I have suggest "Hard Alloy" for neck reinforcement? I'm going to have to stop by the Alloy shop on the way home and see what they have available.
Mike Thomas
Post by Mike Thomas » Thu Apr 23, 2009 8:33 pm
Selmer Maccaferri guitars (i.e. the grande bouche steel string) made in the early 1930's, had necks reinforced with four 12mmx2mm dural bars. Dural is a hard alloy of aluminium with copper, manganese, and magnesium, and was used in the aircraft industry at the time. Apparently, those necks were very stable. According to Wikipedia, the modern aluminium equivalent of Dural (a trade name), is AA 2024.
Mike Thomas
Post by jeffhigh » Thu Apr 23, 2009 9:35 pm
I think warwick used to use adjustable aluminium truss rods in their bass necks. Apparently they tended to break.. I guess the threads were a weak spot.
Dennis Leahy
Post by Dennis Leahy » Fri Apr 24, 2009 12:40 am
OK, Thanks, Jeff. That makes perfect sense.
p.s. BTW, I just ordered some CF round tubes for my next two guitars (neck block to tail block "suspended bracing"), as well as 45° Carbon Shear Web for brace lamination from The Composites Store. Thanks again to David via John , spurred by Kim. :D
Another damn Yank!
Users browsing this forum: Google and 68 guests
