G'day all,
I'm building two concert size guitars as a batch. One will be to the Scott Antes concert plan, 25.5 inch scale with the bracing lightened up considerabily. It's soundhole size is 95mm. The other is a 0-18 Martin concert size guitar copy with 24.9 inch scale and light bracing. Bob Connor has kindly sent me a pic of an original Martin 0-171937 top as a guide to work off. The body is 345 mm LB, 250 UB, 460 L, tail thickness 105 and nech block 85 mm. Top is sitka 2.75 mm thick and back and side Indian Rosewood just under 2mm.
My question is dose the size of the soundhole affect the volume of an instrument? I have been told on good authority that a larger soundhole will boost the treble.
All thoughts greatly received. I'm on hoildays all next week and would like to start on the rosette and soundhole so I have to make a decision on a size.
What Soundhole Size?
- ozziebluesman
Last edited by ozziebluesman on Fri Apr 10, 2009 11:19 pm, edited 1 time in total.
- DarwinStrings
Hi Alen here is some reading for you mate on the soundhole size question. http://hal9000.ps.uci.edu/Weber%20H90%2 ... 0Paper.pdf
- ozziebluesman
Thanks Jim,
Some interesting findings in that article!
I often wondered that a sound port would have to affect the overall volume of an instrument too!!
Think I will go with the size Martin use! Proven and tested!
- DarwinStrings
Users browsing this forum: No registered users and 160 guests
