Neck vise/rest for setup work
Rod True
Siberian Tiger
Post by Rod True » Sat Apr 04, 2009 5:09 pm
Well, I've had this really poorly made (by me) neck rest which I was using for the past 5 years and it was time for an update.
Here's the old neck rest, bad eh?
Ya, ugly too. It worked ok, but certainly not great. So I needed something that was going to really hold the neck steady, yet I wanted to be able to access the frets for leveling etc...
I've always liked the guitar vise that (I think) Brian Gallop designed and David Collins showed on the OLF, but I'm a cheap skate and didn't want to purchase the vise screw :D
Here's a picture of the Gallop bench vise (David Collins picture)
Nice eh? So, I was thinking, how could I make something similar to that, only smaller and on the cheap.
So, here's what I came up with.
Just a few pieces of wood and a piece of threaded rod (could use a carriage bolt too). Took me about 20 mins to think up and make and it works really well.
As you can see, I cut a few kerfs in the arms to help them bend in when I tighten the screw. I have to put something over the threaded rod so I don't damage a neck, a piece of leather like David has would work great (now I just need to find a willing cow :D )
Cheers.
Post by Bob Connor » Sat Apr 04, 2009 5:12 pm
I love your work Rod.
Consider it stolen.
What's it called?
"The True Grip"
Rod True
Siberian Tiger
Post by Rod True » Sat Apr 04, 2009 5:20 pm
Da Grippa! LOL
or how bout "The Head Lock"?
Steal away my friend, that's the idea. Oh you'll have to send me $25 for the.....oh, never mind :twisted:
Post by Allen » Sat Apr 04, 2009 5:41 pm
I've been looking at lots of different ideas for something like that Rod, and yours is brilliant. If you used a piece of leather like from a wide belt, then it could be used as a loop, under the neck and attached to the jaws for the non-marring surface.
Thanks for the inspiration. This place is the best.
We're getting so many of these great ideas, that perhaps it would be a good idea to have a "Jigs and Fixtures" section.
Post by Lillian » Sun Apr 05, 2009 1:31 am
I like that Rod. Nicely done. When Hesh showed the vice he built for his bench I thought it was a cool idea, but I really don't have the room for it to stay bolted to the bench and didn't want to fuss with taking it off and putting it back each time I needed it. You have solved my problem very nicely. Thank you. Consider it stolen and shoved towards that top of the list.
Dave White
Post by Dave White » Sun Apr 05, 2009 6:30 pm
Rod,
Simple and elegant like all the best inventions. Oh yes . . . and even better - cheap :D
Dave White
Post by Craig » Sun Apr 05, 2009 8:48 pm
Looks good Rod . Simple and affective
Good idea about a " Jigs and Fixtures " section Allen
Craig Lawrence
John Maddison
Post by John Maddison » Sun Apr 05, 2009 9:11 pm
A very elegant innovation. :wink:
John M
Post by Hesh1956 » Sun Apr 05, 2009 11:23 pm
bob wrote:
What's it called?
Cheney? :D
Post by Hesh1956 » Sun Apr 05, 2009 11:29 pm
Allen wrote: If you used a piece of leather like from a wide belt, then it could be used as a loop, under the neck and attached to the jaws for the non-marring surface.
That's right - the leather loop spanning the two sides of the vice is cheap insurance against having the neck fall through the vice and get messed up...
A good deal of set-up work requires some filing and other operations that need a rock-solid hold on the guitar. In addition the shape of the vice jaws in David's picture have a method to them so as to hold the neck from popping up too when you want the neck in the vice, clamped, but need the fret board completely exposed for leveling, dressing, polishing, etc.
Nice vice Rod!
John Maddison
Post by John Maddison » Sun Apr 05, 2009 11:51 pm
Allen wrote: ...perhaps it would be a good idea to have a "Jigs and Fixtures" section.
Agree entriely, Allen.
So often these great new ideas become lost in the Instrument Builders Forum and Tutorials.
John M
Post by Kim » Mon Apr 06, 2009 12:08 am
This topic has already been moved to the new forum for 'Jigs & Fixtures', please post any further comments there. This shadow was left for continuity purposes only.
pau
Post by pau » Mon Apr 06, 2009 5:02 am
Can't you stick a bit of sponge to the one side of the jig above the bolt while you look for your cow? It's pretty squashy stuff and may do the trick. Or even a strip of carpet.
(Whoops. I didn't read a couple of the replies.)
matthew
Post by matthew » Tue Apr 07, 2009 7:51 am
electrical heat-shrink tubing from DSE is great for covering exposed threads in jigs.
neilmac
Re: Neck vise/rest for setup work
Post by neilmac » Fri Jun 12, 2009 1:16 am
Rod True wrote:Well, I've had this really poorly made (by me) neck rest which I was using for the past 5 years and it was time for an update.
Cheers.
Hi Rod
I'm new here and happened upon your vice idea
I have a perfect solution for you to cover that dangerous bolt:
Go to Billy Hydes Drum section or Drummers Paradise and you will find
packs of inexpensive replacement cymbal stand felts
These are high density felt donuts of goodness and if you thread
your vice bolt through half a dozen or so of them your bolt will be
forever sheathed in felty niceness, protecting those valuable necks from it's cold steel core!
They vary in density , with the Hi Hat felts being the firmest
cheers Neilmac
:D
Rod True
Siberian Tiger
Post by Rod True » Sat Jun 27, 2009 8:56 am
Thanks Neilmac, I got an old leather belt for $1 at the thrift store. It works great.
Post by Kim » Sat Jun 27, 2009 11:19 am
Good tip thanks Neil.
Welcome to the ANZLF 8)
