ANZLF Adjustable Neck Joint Group Discussion
BMS
Post by BMS » Tue Sep 09, 2008 4:28 am
So here is the guitar:
Benoit
www.bmsguitars.com
Post by jeffhigh » Thu Oct 23, 2008 7:12 am
Ok Here is a pic of my neck joint disassembled
The Black strip is 3mmx1mm CF as a bearing strip
The hole in the neck block has a threaded insert installed from the inside.
The bolt is installed from the outside into an enlarged spotfaced hole and doubles as a strap button.
I had to trim a little on the heel face for adjustment range so it is a little rough (shows it is handmade right...)
Post by jeffhigh » Wed Dec 31, 2008 9:28 pm
Just saw this "Triumph" archtop from the 50's ? on ebay
with a stauffer clockkey adjustable neck and an adjustable bridge too
Post by Allen » Wed Dec 31, 2008 10:02 pm
Everything old is new again. Stood the test of time. That's good to know. Thanks for post ing that Jeff.
