Carbatec Drum Sander
old_picker
Re: Carbatec Drum Sander
Post by old_picker » Sun Jun 28, 2015 9:02 am
looks like the trick clip on the performax is on the lhs looking from infeed side.
the carbatecs is on rhs and largely obscured from view. i find a mirror quite helpful and if the paper breaks off at the clip i simply stick it to the drum with contact adhesive.
Post by kiwigeo » Sun Jun 28, 2015 9:06 am
old_picker wrote:looks like the trick clip on the performax is on the lhs looking from infeed side.
Ray, its easiest to work the tool on the left side where there's more room to move your hands but the tool will work on both sides.....the anchoring clips on the Performax drums are the same both sides.
demonx
Post by demonx » Sun Jun 28, 2015 9:11 am
Keep in mind though not all machines are built the same, for example, one of my machines has two fastening clips. The other machine has one fastening clip and one tensioning clip that helps pull your paper tighter.
Post by kiwigeo » Sun Jun 28, 2015 9:30 am
demonx wrote:Keep in mind though not all machines are built the same, for example, one of my machines has two fastening clips. The other machine has one fastening clip and one tensioning clip that helps pull your paper tighter.
Looks like the Carbatec 400mm machine has an anchoring clip right side and tensioning clip right side. Who the hell designs these things...whoever it is should be condemned to a hell where they spend all day changing paper on Carbatec drum sanders.
demonx
Post by demonx » Sun Jun 28, 2015 9:42 am
My little one is the Carbatec 400mm, the updated one they released five/six years ago which was meant to solve some of the issues of the earlier ones. The clips might pull a bit, but nothing like the clips on my twin Leda 635mm. The clips (right side) on that actually help pull the paper tight, the Carbatec sander pretty much relies on you pushing it down in the slot as much as you can.
lauburu
Post by lauburu » Mon Jun 29, 2015 6:04 am
When the designers of British cars were all made redundant, they had to go work somewhere. Obviously one or more ended up designing drum sanders. :(
Miguel
Post by Nick » Mon Jun 29, 2015 6:47 am
Miguel
:lol: :lol: Sounds more like the engine designers got that job Miguel, you know, the ones that put the frost plugs right at the back of the engine where you had 25mm of room to remove the old one and put a new one in!
Post by jeffhigh » Mon Jun 29, 2015 6:57 am
Miguel
Yeah
Had to cut a hole in the firewall of my '56 Jaguar for that...
Post by kiwigeo » Mon Jun 29, 2015 8:42 am
Many years ago I worked in a garage servicing mainly British cars....God I grew to hate most of those vehicles. We had to jack up an old Austin A40 and whack out the starter motor to get to the oil filter. An oil filter change out on mini involved whacking off the front grill....and most of the skin off the back of your hand in the process.
The Morris Marina...now there's a bucket of sh*t.
Post by 56nortondomy » Mon Jun 29, 2015 8:51 am
What about driving a mini in the rain, the water would go through the grill onto the dizzy, ( which was on the front of the motor ) the car would cut out and then you'd have to pull off the cap and spray it with wd40.
lauburu
Post by lauburu » Tue Jun 30, 2015 5:54 am
Common solution in Brisbane was to cut a couple of notches in a plastic ice-cream container and insert between the grille and the dizzy. Even worked during monsoon season.
Sorry, but I think I steered this thread onto a bit of a tangent.
Miguel
Users browsing this forum: Google and 72 guests
