Hi,
A search didn't show much up here.
Does anyone have info on archtop top and back plate laminate molds for either hydraulic or vacuum presses?
Maybe even a CNC file for the male and female molds to place in a press?
I'm avoiding the carved solid top route because of negative comments on cracking / maintenance issues.
I've never owned a Gibson / Epi laminated archtop that had a wood crack issue
Thanks in advance
Mak007
Archtop plates
Re: Archtop plates
There are few Youtube channels that cover ES335 builds using laminates and vacuum presses.mac007 wrote: ↑Fri Jan 27, 2023 3:25 pmHi,
Thanks in advance
Mak007
Cracking and maintenance issues with a carved top instrument......I guess a laminated top is never going to crack but if you look at the evolution of laminated archtops..IMO they were a way to produce a product simulating the characteristics of a carved solid archtop guitar without requiring skilled labour and higher cost materials.
IM about to start an ES335 build based on this guys Youtube videos: https://youtu.be/hMPGVuG1Dvo
Re: Archtop plates
Hi Martin
Thanks for the reply.
Good luck with the 335 build
Aside (I played Fender Stratocasters for most of my +35 year career in the biz and have only recently moved over to hollowbodies as age and tonal maturity advance!!!)
I have found they all differ ,annoyingly, regardless of country of manufacture, year etc etc.
Eg. The latest Epiphone 335's (inspired by Gibson) are superb, but don't play or sound like a Gibson.
FWIW I just bought, for a lot of money, a Gibson '90's ES 135 and it's a charmer. Solid (balsa?) block and PAF's.
I'm about to build an ES 175 and will probably pay the $7-800 for a set of plates and body from these Finnish guys at archtoplaminates and build up from there.
They use Scandivanian spruce laminate, measure Y modulus data and seem care about the product.
I'll let you know how it goes- setting up an archtop press with molds etc seems a big ask for small time hobby builders.
Mak007
Mak007
- rocket
Re: Archtop plates
I have a little bit of experience with archtops and i haven't had any negative experience with the solid carves in regards to cracking at all.
as a matter of interest with all the forums and social pages i peruse i don't recall any issues in general about carved arch top plates being prone to cracking,,, seen heaps of flat tops with cracks in them though! Juss sayin
Users browsing this forum: No registered users and 303 guests
