Oil Based Varnish Mix
Post by ozziebluesman » Fri Feb 03, 2017 10:01 pm
Hello to you all,
A builder friend of mine asked me a question the other day about hand finish.
He would like to use an oil based varnish recipe to finish a violin.
Apparently there are spirit based finish recipe's as well.
I know very little so if anyone has some thoughts I would be very interested.
Thank you.
Re: Oil Based Varnish Mix
Post by Mark McLean » Fri Feb 03, 2017 11:24 pm
Lots of options with oil based finishes, applied by hand. I have done this in all five guitars that i have built. Danish oil is often used but I find it is a bit slow to cure , and this is likely to be worse in tropical areas like yours Alan. Tru Oil has been used by lots of folks for guitars and I have done two with this finish. It is marketed as a gun stock finish (buy it from gun shops). It dries very hard and tough. If you slowly build many layers it can be levelled and buffed out to a very gloss finish. It also looks as a satin finish, which is a lot less work. I have also used "Hard Wax Oil" which is a product for hardwood flooring. Easy to apply by hand and it is very hard when dry. None of these are going to achieve a glass-like high gloss nitro type of finish loke most factory built guitars. I actually don't like that anyway. If your mate is making a violin then a gloss finish is not the usual thing anyway.
Post by Allen » Sat Feb 04, 2017 7:10 am
Post by ozziebluesman » Sat Feb 04, 2017 9:49 am
Thanks Allen
Post by ozziebluesman » Sat Feb 04, 2017 9:52 am
Thanks Mark.
I was more interested in some of the old style varnish recipes used by the Luthiers of yesterday.
I think they keep their finish process close to their chest as there are probably years of experimenting gone into getting their particular process and recipe right.
Post by kiwigeo » Sat Feb 04, 2017 10:43 am
ozziebluesman wrote:Thanks Mark.
Aaaah yes....those "secret" recipes.....well now you know why theyre called "secret". :D
Ive got a library full of GAL mags and Big Red Books and I recall there being a few articles on violin finishing..Ill have a look and see what I can find for you. In the mean time....here's one interesting site: https://www.violins.ca/varnish/violin_v ... cipes.html
blackalex1952
Post by blackalex1952 » Sat Feb 04, 2017 11:48 am
Interesting. On the same website, a glossary of some of the ingredients:https://www.violins.ca/varnish/violin_v ... ssary.html
Post by ozziebluesman » Sat Feb 04, 2017 12:44 pm
Thank you Martin that is the information that I am looking for. I mean you will obviously test the potion on some scrap and see if it's going to do what you want.
Al
