Bottle slide setup
- ozziebluesman
Bottle slide setup
Another question is I have a friend who has an Epiphone acoustic with a zero nut and he would like to convert it for bottle slide.
Is that possible?
Any thoughts on this would be much appreciated.
Is that possible?
Re: Bottle slide setup
If he wants to play entirely with a slide - in other words never fret a note ever again - it should be no problem. In that situation the position of the frets, including a zero fret, is irrelevant. In fact they could all be removed and it would make no difference. Guitars with a zero fret still have a nut to achieve correct string spacing but it doesn't detetmine string height. If that nut was replaced with a taller one to achieve a high action for slide playing then the strings will no longer be in contact with the zero fret. This will mean that the scale length will be a bit longer than before, and every fret will be a bit out of position to produce the appropriate pitch for that fretted note. However, slide playing should not be affected.
- ozziebluesman
Thanks Mark, I have no experience with the zero nut. Your explanation makes sense. Thank you!
It depends on his style of playing. Does he combine fretted notes with slide notes? Many players do and if this is the case you will not want a greatly increased action.
I would not replace the nut, all that would possibly be needed would be to raise the saddle and maybe install a slightly higher section zero fret.
But again, it depends on what he needs out of the guitar
- ozziebluesman
G'day Jeff,
Yes he would want to fret as well as slide.
I will try a jumbo fret closest to the nut and see how that feels. The strings only have to be about 1.5 to 2 mm from the frets which a well worn and then 3 to 4 mm from the 12th fret. That's the drift I have researched anyway.
Thanks for your input.
If he wants to fret notes as well as slide, then you have the right plan - a taller zero fret and raise the saddle a bit. Hope it works out well. M
- ozziebluesman
I made a nut to fit in between the zero fret and the nut.
The intonation is not perfect but close enough for old style blues.
Thanks for all your discussion.
- IMG_6456 (640x480).jpg (203.45 KiB) Viewed 8752 times
- IMG_6457 (640x480).jpg (177.87 KiB) Viewed 8752 times
That'll work. Good fix
mm
mm
Users browsing this forum: No registered users and 88 guests
