White spirit cleaner
- rocket
I have some adhesive residue left on the binding after removing the masking tape and I'm just a little concerned if I use the white spirits to help remove it will the be any adverse effect when applying the pre cat lacquer.
Any advice?
Cheers. Rod.
Any advice?
Cheers. Rod.
Re: White spirit cleaner
Shellite shouldn't be an issue......I use it for cleaning up wood surface prior to finishing.
- rocket
Thanks Martin, I thought I Was on the right track but it doesn't hurt to ask.
Shellite is naptha....it will flash off and shouldn't leave a residue of any sort. I sometimes use it to clear oil that's bled out during French Polishing sessions.rocket wrote:Thanks Martin, I thought I Was on the right track but it doesn't hurt to ask.
Diggers "white spirit" is a different product to their Shellite, more akin to dry cleaning fluid.
Probably ok for this application but may not be finish safe on lacquer/shellac like the shellite/naptha
The white spirit seems a bit "oily" to me...I only use it for cleaning chisels etc.jeffhigh wrote:Diggers "white spirit" is a different product to their Shellite, more akin to dry cleaning fluid.
- rocket
ok so is sheltie or naphtha available at Bunnings?
Shellite should be available at Bunnings...I get it from my local Mitre 10. Diggers brand.rocket wrote:ok so is sheltie or naphtha available at Bunnings?
- rocket
Thanks Martin, i'll pop down and see if my local has some in stock.
- Steve.Toscano
I dont want to seem like im stating the obvious, But im abit confused as to why the big effort. Surely the residue would come off during the scrapeing & sanding process?rocket wrote:I have some adhesive residue left on the binding after removing the masking tape and I'm just a little concerned if I use the white spirits to help remove it will the be any adverse effect when applying the pre cat lacquer.
Any advice?
Cheers. Rod.
It's often alot quicker cleaning off the residue with Shellite. Some tapes leave a residue that doesn't sand off that easily and during the sanding process the goo gets dragged around and gums up the paper. Some double sided tapes are really bad for this.felix wrote:I dont want to seem like im stating the obvious, But im abit confused as to why the big effort. Surely the residue would come off during the scrapeing & sanding process?rocket wrote:I have some adhesive residue left on the binding after removing the masking tape and I'm just a little concerned if I use the white spirits to help remove it will the be any adverse effect when applying the pre cat lacquer.
Any advice?
Cheers. Rod.
- rocket
Yeah what Martin said!!
That's what I use the diggers shellite.
It gets confusing with different names used in different countries
Potentially disastrous results if you put the wrong stuff in your stove.jeffhigh wrote:That's what I use the diggers shellite.
- Steve.Toscano
ohh I see, makes sense thanks. I've never experienced a problem, I just go nuts with a scraper taking any tape left behind and glue squeeze out off with it.kiwigeo wrote: It's often alot quicker cleaning off the residue with Shellite. Some tapes leave a residue that doesn't sand off that easily and during the sanding process the goo gets dragged around and gums up the paper. Some double sided tapes are really bad for this.
Users browsing this forum: Google and 82 guests
