White spirit cleaner
Post by rocket » Wed Sep 21, 2016 3:15 pm
I have some adhesive residue left on the binding after removing the masking tape and I'm just a little concerned if I use the white spirits to help remove it will the be any adverse effect when applying the pre cat lacquer.
Any advice?
Cheers. Rod.
Re: White spirit cleaner
Post by kiwigeo » Wed Sep 21, 2016 4:20 pm
Shellite shouldn't be an issue......I use it for cleaning up wood surface prior to finishing.
Post by rocket » Wed Sep 21, 2016 4:26 pm
Thanks Martin, I thought I Was on the right track but it doesn't hurt to ask.
Post by kiwigeo » Wed Sep 21, 2016 6:33 pm
rocket wrote:Thanks Martin, I thought I Was on the right track but it doesn't hurt to ask.
Shellite is naptha....it will flash off and shouldn't leave a residue of any sort. I sometimes use it to clear oil that's bled out during French Polishing sessions.
Post by jeffhigh » Wed Sep 21, 2016 7:03 pm
Diggers "white spirit" is a different product to their Shellite, more akin to dry cleaning fluid.
Probably ok for this application but may not be finish safe on lacquer/shellac like the shellite/naptha
Post by kiwigeo » Wed Sep 21, 2016 8:34 pm
jeffhigh wrote:Diggers "white spirit" is a different product to their Shellite, more akin to dry cleaning fluid.
The white spirit seems a bit "oily" to me...I only use it for cleaning chisels etc.
Post by rocket » Wed Sep 21, 2016 9:02 pm
ok so is sheltie or naphtha available at Bunnings?
Post by kiwigeo » Wed Sep 21, 2016 9:08 pm
rocket wrote:ok so is sheltie or naphtha available at Bunnings?
Shellite should be available at Bunnings...I get it from my local Mitre 10. Diggers brand.
Post by rocket » Wed Sep 21, 2016 9:13 pm
Thanks Martin, i'll pop down and see if my local has some in stock.
Steve.Toscano
Post by Steve.Toscano » Wed Sep 21, 2016 11:03 pm
rocket wrote:I have some adhesive residue left on the binding after removing the masking tape and I'm just a little concerned if I use the white spirits to help remove it will the be any adverse effect when applying the pre cat lacquer.
Any advice?
Cheers. Rod.
I dont want to seem like im stating the obvious, But im abit confused as to why the big effort. Surely the residue would come off during the scrapeing & sanding process?
Post by kiwigeo » Thu Sep 22, 2016 8:33 am
Any advice?
Cheers. Rod.
It's often alot quicker cleaning off the residue with Shellite. Some tapes leave a residue that doesn't sand off that easily and during the sanding process the goo gets dragged around and gums up the paper. Some double sided tapes are really bad for this.
Post by rocket » Thu Sep 22, 2016 8:50 am
Yeah what Martin said!!
Post by jeffhigh » Thu Sep 22, 2016 10:25 am
That's what I use the diggers shellite.
It gets confusing with different names used in different countries
Post by kiwigeo » Thu Sep 22, 2016 12:49 pm
jeffhigh wrote:That's what I use the diggers shellite.
Potentially disastrous results if you put the wrong stuff in your stove.
Steve.Toscano
Post by Steve.Toscano » Thu Sep 22, 2016 2:46 pm
kiwigeo wrote: It's often alot quicker cleaning off the residue with Shellite. Some tapes leave a residue that doesn't sand off that easily and during the sanding process the goo gets dragged around and gums up the paper. Some double sided tapes are really bad for this.
ohh I see, makes sense thanks. I've never experienced a problem, I just go nuts with a scraper taking any tape left behind and glue squeeze out off with it. :lol:
Users browsing this forum: No registered users and 90 guests
