HELP! Petrol spill on my NGRW
I just bought my first plank of tonewood. 155x29x1250 perfectly QS NGRW. It has been sawn for at least 20 years. If you tap it it rings pure for about 5 or 6 seconds and then, takes another second or 2 for the tops to decay as the bass rolls on. I paid $12.40 for it. It looks good.
I spilled petrol on one end. Should I wash it with water, ethanol, nothing, something else?
Martyn
Great minds like a think!
- woodrat
Re: HELP! Petrol spill on my NGRW
Hi Martyn, I shouldnt worry too much about it, most of it should have evaporated away and any residue should be sent flying as you mill/saw/sand it. At 29mm thick I expect that you are going to resaw it and then sand or plane to thickness. Therefore it should be lost in the process. Nice find though!
Go for it!
The WoodRat
aka John
Go for it!
The WoodRat
aka John
For most things like that you can use Shellite to clean any residue off if it really worries you. With gasoline you're not going to have much left unless you've mixed it with oil for a 2 stroke engine.
I was worried about it staining.Allen wrote:For most things like that you can use Shellite to clean any residue off if it really worries you. With gasoline you're not going to have much left unless you've mixed it with oil for a 2 stroke engine.
Martyn
That is what I hoped to hear. $12.40 seemed like a bargain at the time but I am feeling the withdrawal symptoms all too soon.woodrat wrote:Hi Martyn, I shouldnt worry too much about it, most of it should have evaporated away and any residue should be sent flying as you mill/saw/sand it. At 29mm thick I expect that you are going to resaw it and then sand or plane to thickness. Therefore it should be lost in the process. Nice find though!
Go for it!
The WoodRat
aka John
Unless I am badly mistaken, I seem to have fast onset WAS!
Also I am now tempted to try to resaw this and do it before, or in conjunction with the sets I got from you.
I get the saw on Tuesday.
Martyn
- Tod Gilding
Hey Ya Martyn,
Is there a cure for WAS
because I'm getting a bad dose of it,there's no use asking the woodrat for a cure, he's got the full blown disease and doesnt care, I've seen his stash.
Cheers Tod
Cheers Tod
- woodrat
Shhhhhhhhhh Tod!!!!!!!!!
The WoodRat
Aka John
Aka WAS sufferer
The WoodRat
Aka John
Aka WAS sufferer
I think that if I can save 1 plank of tonewood every time I use my car, that I can more than offset my carbon footprint!
Probably?
Now if only I can convince the wife.
Probably?
Martyn
She says she is convinced as long as I shut the F up.. whatever that is...Tonxi wrote:I think that if I can save 1 plank of tonewood every time I use my car, that I can more than offset my carbon footprint!
Probably?
SORTED!
Martyn
When you spill hydrocarbons on wood, you should ask " what would Jimi do?"
A lighted match waved over the wood will soon get rid of that nasty petrol smell lol
- Taffy Evans
My first time back for a while have things changed? site looks different or is it my computer.
Anyway, I had this big log of Burdekin Plum some years ago and some borers had got into part of it, a mate of mine who knows about these things said he could get rid of them and doused the timber in avgas from his chopper. It worked and no staining.
- woodrat
Hi Taff, What was the application distance from the chopper?
The WoodRat
The WoodRat
I can't even afford a compressor and spray gun setup let alone a chopper!woodrat wrote:Hi Taff, What was the application distance from the chopper?![]()
The WoodRat
I bet it gives a great finish though!
Martyn
- Taffy Evans
No, No, No, you dont have to buy a chopper, you just need someone with access to flying fuel, or the likes.
JP8 burns nicely.
Taffy, its been a while since your last visit. Bob switched host after the meltdown and went through a software upgrade. You ought to drop by more often and visit . We enjoy your company.
Users browsing this forum: Google and 45 guests
