Calculating neck and fingerboard specs
tim mullin
Post by tim mullin » Tue Jan 25, 2011 12:28 pm
I find myself adjusting my fingerboard dimensions (scale length, nut width, string-spacing, taper, string setback, etc) on almost everybuild, and I confess I've sometimes made errors in my calculations. For my latest guitars, I decided to get this sorted into a spreadsheet to do the calculations easily and without error! I've posted the spreadsheet on my website under "Other pages", and you can find a link here: http://www.mullinguitars.com/calculatin ... tback.html
The cells in blue font are user changeable and are where you enter the proposed specs for your instrument. You can enter in metric or decimal inches, or you can enter a formula to convert, say, a client spec given in inches (which is pretty common in factory literature) to metric (which is how I build). The calculations are then automatic. If you don't want equal string setback on both treble and bass, you can fiddle with string spacing at the nut to give you the desired setback at the nut for one side, then all other positions are calculated for that same side.
I hope this helps someone -- it's certainly helping to keep my records straight.
Kim Strode
Re: Calculating neck and fingerboard specs
Post by Kim Strode » Tue Jan 25, 2011 6:01 pm
I tried to alter the blue numbers on the spreadsheet Tim, but a window comes up indicating the page is password protected and cannot be altered - is there a trick that I'm missing?
Kim Strode
Daylesford, Australia
Post by Allen » Tue Jan 25, 2011 6:35 pm
I get a message saying the spread sheet is encrypted and can't be opened.
tim mullin
Post by tim mullin » Tue Jan 25, 2011 6:46 pm
Oh dear, I do have a love-hate relationship with Microsoft.
I expect some ofthe problems may have to do with my trying to save a worksheet with protected cells in Excel 2010, but in a format compatible with Excel 2003 (I didn't think everyone would have access to the latest version). Did anyone manage to open and use the original spreadsheet, or was everyone getting errors?
I've reposted the download link on my website, removing ALL worksheet protection (so, if you fiddle with parts outside the blue cells, I can't guarantee the accuracy of the calculations). The only thing that might happen now is that you may be warned that the file originated from the internet and you will have to "Enable editing".
Please, someone tell me it works for you now?
Post by Allen » Tue Jan 25, 2011 6:50 pm
I don't have MS office on my Mac. But iWork Numbers opens just about anything I through at it. However I'm still not getting any lovin from this spread sheet. Says it's encrypted and can't import and open.
Post by Dominic » Tue Jan 25, 2011 7:11 pm
I had no problems with them on 2003. Thanks Tim.
But I gotta say, Excel 2007 and 2010 are total dogs. I use excel pretty much all day at work and they are a giant leap backwards in terms of productivity. What was MS thinking??
Kim Strode
Post by Kim Strode » Tue Jan 25, 2011 7:19 pm
Thanks Tim, Works for me now.
Kim Strode
tim mullin
Post by tim mullin » Tue Jan 25, 2011 7:31 pm
Allen wrote:I don't have MS office on my Mac. But iWork Numbers opens just about anything I through at it. However I'm still not getting any lovin from this spread sheet. Says it's encrypted and can't import and open.
Ok, I think I finally have a version of the sheet that should open on anything -- including Mac Office and iWork, The sheet is now completely unprotected, so if you inadvertently change a formula, you'll have to accept responsibility for the result (which was the reason I tried to protect some cells, but didn't anticipate the compatibility issues).
Apologies -- hope the new version is helpful.
Kim Strode
Post by Kim Strode » Tue Jan 25, 2011 7:39 pm
I can open the sheet in numbers now Allen.
Kim Strode
Post by Allen » Tue Jan 25, 2011 8:13 pm
All good now Tim.
I'll play with it and perhaps I can protect the areas that need it and it should be good on my system.
Cheers mate.
Post by Lillian » Tue Jan 25, 2011 11:30 pm
Open Office solves 99.9% of Microsoft headaches. And its free. I use Open Office Oxygen.
Paul B
Post by Paul B » Wed Jan 26, 2011 12:23 am
Dominic wrote:What was MS thinking??
Users browsing this forum: Mike Thomas and 84 guests
