"Williams"-style binding channel router jig
Hello all:
As my first contribution to the forum, I thought I would share my rendition of the "'D.E. Williams" binding channel router jig. It's got to be my favourite non-commercial tool in the shop.
I pretty much followed the instructions given on Williams' web site: http://www.dewguitars.com/BindingJig/Binding%20Jig.htm . Perhaps the hardest part to source is the UHMW plastic "donut" -- I used UHMW bought from Lee Valley Tools on a visit to Canada, and the machining was done on my drill press and router table.
I like the jig, because the guitar remains stationary and I guide the router with my hands -- seems more natural than the other way around, and I feel I have absolute control while ensuring that the router is always dead vertical.
There are two parts, the carriage, and the articulated, telescoping swing arm that holds the router. The carriage is clamped to my bench when I need it, and the arm is screwed to an indexed position on the bench top ...
The guitar is secured in the carriage with the soundboard level (ensures on my guitars that the sides are vertical). The arm reaches all edges to be cut.
The router rides on the UHMW "donut" so that it is not affected by curvature.
Also makes routing of headstock binding channels easy -- you can always see what you're doing ...
The only "con" to the jig, is that it takes up considerable space for storage when not in use, but I think that's a minor point.
Hope that helps someone!
Tim
Tim
Welcome to the forum Tim, good to see another "Kai Wai" joining the forum. Good first up post too, pictures, information what more could we ask Looking forward to your comments & contributions to this little corner of the Luthiery planet
Nice binding jig, I can see what you are saying about the 'con' tho! it does tend to take up space but looks like it cuts nice and square which, after all, is the main aim of a binding jig.
Hi Tim,and welcome. Just whack a shelf up high on the wall and stick this and other useful things on top.You can never have too many shelves.Looks like a good jig to keep around so I suppose I will have to steal your idea.
Cheers from Micheal.
Remember the "5P Rule".
[img]http:www.pegasusguitars.com/Router.jpg[/img]
Having never posted in your forum, I'll see if I have figured out how to post an image and then do another post if it works. If it doesn't, oh well!
Welcome Tim and Bob!
Tim I use the exact same jig and love it. You're right it takes up some space but that can be easily remedied by simply moving to a new shop with a house that comes with it...
My Williams jig was made by Don himself and he also signed it for me.
Not that I would try this but it's been said that one can route a guitar blindfolded with this jig its so very easy to use.
Welcome aboard guys.
Might make for an interesting binding channel! It's my fingers/hands I'd be more worried about using this 'blindfold' techniqueHesh1956 wrote:Not that I would try this but it's been said that one can route a guitar blindfolded with this jig its so very easy to use.
It looks to be the LMI bit and bearing set Micheal. Same one that I have.
I think it's probably the best for doing ledges on guitars, because you don't have to think about which ledge you're going to cut first, the one for the purfling, or the binding.
With the short cutter like Stew Mac sells, you pretty well have to do the purfling first then the binding channel, or you don't have a spot on the side to reference off of.
Allen M8 Stew-Mac has fixed their binding router bit set so that it no longer matters if you do the purfling channel first or not. They added a simple brass spacer that prevents the business end of the bit from falling into the binding channel if you cut the top purfling channel first.
I have both bits mostly because my Stew-Mac one started getting dull and I am too lazy to sharpen it. I do like the LMI set better with more bearing choices in the standard package - but we do pay for that too....
How do you get any work done Hesh if you can't spend 30 secs. rubbing a router bit on a diamond plate.started getting dull and I am too lazy to sharpen it
The jig works great and makes a tedious job easy.
Binding channels cut
Silver ash binding installed
Users browsing this forum: No registered users and 90 guests
