My Binding Jig
My Binding Jig
Because of the interest shown in binding jigs here of late ,I've put together a few pics of my jig I made a few years ago ,
I got my basic idea from the Jim Williams book ,but have made a number of changes. Arnt has one similar as well.
I have stuck with my dremel as the power source ,so as to not make it too top heavy. Despite what others have said , I find it to have ample power for the job , but do it in two passes , and follow the Stewmac cutting directions ( on their site.)
I also have the power cord hung from a ceiling hook so that the unit isn't being pulled from any direction.
I use the bit shown for the binding ledge , but change to an 1/8 " spiral downcut for the purfling ledge ( shellac the soundboard edge first too! )
The donut piece I've eventually decided on is small enough to not alter the depth of cut ( about 1 1/2 "), yet wide enough so I can still feel the unit to be registering upright . With a very small donut , you can easily tip the thing. I have also chamfered the front of it enough to clear the the top/back radius.
This unit utilizes half of the Stewmac router base which I simply unscrew when required . It is micro adjustable in hieght, thanks to Stewmac and also micro adjustable in cutting depth . I undo the four hex head screws on the underside of the unit , then adjust the aluminium mounting plate (which rides on the mahogany base ), to or fro with the adjusting wheel at the end of the unit . Relock the 4 hex head screws
Craig,
All of the stuff you have made, every jig, tool, component, guitar, what ever, that I see you post, looks like it is come straight from the pages of a ritzy fine woodworking mag.
Man your one shithot craftsman.
For those who have not have the opportunity to see them before, could you please show us your thickness calipers.
O.K Kim ,here it is for those who haven't seen it before. My over the top thickness caliper. Mad ! ,I know , but it works flawlessly and I can recalibrate it should it be required. (Haven't so far )
There's actually much more function to it ,than meets the eye , but too lengthy to go into at the moment
Craig Lawrence
Craig Lawrence
- Ron Wisdom
- Dennis Leahy
- sebastiaan56
Hi Craig,
That is fully sick mate! (had to mix the metaphores, 12yo over my shoulder). The mounting plate and depth bolts are your own work right? Have you documented any of the dimensions type stuff? I want one!
Repeat all of the above for the caliper, just add "love the guitar" adds that touch of class,
Sebastiaan
Sebastiaan
Cheers everyone , much appreciated .
Billy ,your Avator cracked me up !!
Here's some more pics :
The upper bout of the little guitar becomes the cam , and the lower bout becomes the counter weight . There is moveable round counter/counter weight on the indicator arm. Aluminium ,Brass, Copper for the scratchplate etc. and bronze for the slide
I made this from a copper pipe I split open . Scribed and filled. It's in Millimeters
- Ron Wisdom
- Graham W
- Kauri
0.168 1905.8811772
Wow, Craig. If your guitars are half as good as those jigs, and from the photos it looks like they are, then they'll be absolute masterpieces!
Graham W
Graham W
Graham Wardrop
PO Box 18 845
Christchurch 8641
New Zealand
guit.art@clear.net.nz
PO Box 18 845
Christchurch 8641
New Zealand
Alain,,,,,, Don't laugh now !
From memory it was a piece of brass scrap off something ?? . I tapped a thread in it,, locked a threaded shaft in it with 2 nuts,and 'turned ' it with a file on my drill press ( like a lathe). I partly filled the rebated part with blackened epoxy to lock it on the thread ( and look cool ! )
Please let me know if you think I'm going ( or have gone ) insane
Cheers Craig
Cheers Craig
Craig man, i mean WHEW HEW HEW HEW! What a nice caliper!
I wish i had one fraction of your skills man, i'm sending you a reporter for an interview, we gotta have this on film, way too neat brother!
Lillian, thanks for that pic, i'll see what i can come up with, still got a pile of junk here that needs to be used intelligently!
