Emoticonitis
Emoticonitis
Since becoming addicted to this forum (which is great) I have noticed that many of you luthiers seem to suffer from a common affliction which I can only describe as emoticonitis. In advanced forms, rashes of the things appear all over the place.
My question is: if I continue to attempt to build guitars, will I catch this too? I have a day job (to pay for wood and tools of course) - will they start appearing in my engineering reports??? If so, what is the correct emoticon for "your piles are undersized and your building will fall down if you don't fix them"
How should I best protect myself??
Concerned[img]
Auckland
Oh God. its happening already.......
Concerned[img]
Auckland
Re: Emoticonitis
I'm sure there are others that might be more appropriate, but you can always use followed with the message, "Oh, you were serious. Well then, you might want to fix that then."seeaxe wrote: If so, what is the correct emoticon for "your piles are undersized and your building will fall down if you don't fix them"
- Taffy Evans
Re: Emoticonitis
I wished my piles were undersized, the oversized one I had hurt like hell but I didn't realise it had anything to do with the structural integrity of my building.seeaxe wrote:"your piles are undersized and your building will fall down if you don't fix them"
Re: Emoticonitis
[quote="Toejam
Jim[/quote]
If you want to see some whoppa piles then check out Hesh's emoticon.
<== Hesh busting his gut to get the gas past his piles
Jim[/quote]
