#012 - "3 Planks" 6 String fretless bass
Posted: Sat May 12, 2018 1:01 pm
Been a while since I've post on here, but here's my latest effort.
Specs are as follows...
Scale: 39"
Strings: White tapewound La Bella Strings (last set unfortunately)
Neck: 5 piece laminated Victorian Ash, single double action truss rod, graphite bars, Jarrah fingerboard, 20" radius. Bolt on headstock of recycled Aussie hardwood (same as body) with custom string anchors. Laminated, recycled bone and veneer nut. Custom neck and body joining system.
Body: Recycled Aussie hardwood wings, unsure of species or origin. Used to be a desk top.
Bridge: Laminated Jarrah and veneer.
Tuners: ETS headless tailpiece.
Electronics: Nordstrand Audio custom thin DC6 humbuckers, 26mm piezo discs, passive blend system.
Weight: 4kg
The genesis of this bass came from a guitar now affectionately called, "Skeletor". Basically I was trying to do two thing...
1. Have an electric guitar where the body is physically influenced by string tension and the resonance, some what like an acoustic.
2. Building an electric guitar with the least timber possible, with simple construction and fewer steps involved in building.
I call the construction system "3 Planks".
Here's a clip of the bass...
https://soundcloud.com/simpleinnovation ... s-finished
Scale: 39"
Weight: 4kg
