Page 1 of 1
Looks like a guitar
Posted: Thu Oct 25, 2012 1:29 pm
by Bruce McC
Some pictures of an all mahogany OM that I finished recently.
Plain and unadorned, it looks like a guitar and even sounds like one.
Top back and sides Macassar mahogany bought on eBay.
Neck Qld maple
Finger board EI rosewood
Tuners Golden Age from Stewmac
[/attachment]
Re: Looks like a guitar
Posted: Thu Oct 25, 2012 1:52 pm
by deadedith
I like that a lot - good job! The 'plain, unadorned' look has always appealed to me.
What was your finish type and procedure?
Posted: Thu Oct 25, 2012 3:53 pm
by 68matts
Beautifully simple and elegant Bruce, love it.
Although I'm a bit sus on the plant in the background of the headstock shot, seeing as it's in Canberra I thought maybe that's what makes the politicians carry on like children during question time
Posted: Thu Oct 25, 2012 3:54 pm
by Kim
Very cool looking guitar you've made there Bruce. Loads of class & style..
Posted: Thu Oct 25, 2012 4:06 pm
by nnickusa
Ditto, ditto and ditto.
Nice. And, yes, please what did you finish with. I want that satin look on my current one....I've got tru-oil....
Posted: Thu Oct 25, 2012 4:16 pm
by Bruce McC
Hi Dave
The finish is Danish oil, several applications worked in with 400 and 600 wet and dry.
Initially I sealed the body/neck with dewaxed blonde shellac then started the oiling using
400 wet and dry to spread the oil. I applied the oil generously and evenly then wiped off
any excess with a clean soft cloth after about 30 mins. Then I left it for a couple of days
until the surface was dry before applying the next coat. I repeated this procedure changing
to 600 wet and dry.
Posted: Thu Oct 25, 2012 6:16 pm
by Clancy
I recently had a rather enjoyable half hour playing this fine instrument in the hallowed halls of Parliament House.
While noodling away on a bit of The Oils 'No Reaction', I started to wonder if Pete would poke his dome in through the doorway & give us a dance.
You've done well with this one Bruce!
Posted: Thu Oct 25, 2012 6:42 pm
by 68matts
Did you apply any of your Gore/ Gilet knowledge into this one Bruce?
Posted: Thu Oct 25, 2012 7:24 pm
by Bruce McC
Thanks for the kind comments.
Dear Matthew
The vegetation you refer to is a seven lobed dissected leaf variety of Acer palmatum, very common in Canberra.
I have no idea as to what you are alluding to. (TICFIB)
This guitar was partially completed when I attended Trevor's course in June, so I was not able
to apply everything I learnt at the course to this one. I will only say that the resonant frequencies
for T (1,1)1 and T(1,1)2 are well above the suggested ranges and there is no obvious T(1,1)3.
I have fiddled with the bracing and sound hole diameter to move the resonant frequencies away from
note frequencies. I think it worked.
Posted: Thu Oct 25, 2012 7:43 pm
by 68matts
Thanks Bruce, I'm glad it has worked out well for you, it certainly looks the goods.
Thanks also for the info on Acer palmatum ( Now that I think about it that might be the politicians problem, they're smoking the wrong plant
Posted: Thu Oct 25, 2012 7:55 pm
by ozziebluesman
Very nice Bruce. I like the all mahogany look. Your headstock looks grand and the workmanship is first class.
Thanks for sharing the pictures.
Posted: Thu Oct 25, 2012 8:39 pm
by Trevor Gore
Nice one Bruce. Very Martinesque.
I bet it sounds killer with 13s and a slide.
