My First Nylon.
My First Nylon.
Hi All,
This is My first Nylon , it was a Steep learning Curve, Although I did have some Guidance from my mate Justin Montifiore. It was made for the same guy who I made the black and white Tele (guitar , not TV set) for , his brief was," I hate the feel of all the Nylon's I have tried, I hate the Look of all the Nylon's I have seen, I want it too feel like a Steel string in terms of the neck , I want it to look different from a Normal Nylon , I want to it to have a Pickup that reproduces the sound of the guitar , not the strings , and I want it to be Cutaway" . So This is what I have come up with, I used a plan as a rough guide , It has Falcate Bracing , but instead of a Transverse brace , It has a plywood ring around the soundhole that blend's up into the sides and becomes part of the neck block , It then has a Transverse brace that is 10mm down off the soundboard that supports the soundhole ring, and is attached by small blocks to the sides at the waist , with flying braces coming off that junction back to tailblock , Think Smallman meets Gore. the linings around the top are Laminated , the Neck is Bolt On , Bob Connor Style . The back and Sides are Monteray Cypress and the Top is Sitka , the Neck is QLD maple with a Rosewood lamination , the Binding's and Headplate are also EIR , the Pickup Is the K&K Ultra Pure active . It took ages to Complete and has caused it's headaches , But I'm well chuffed with the final result , as for the Sound I have nothing to compare it with , So i'll take it for a visit to Jeff and let him give his Critique, but for my money it sounds pretty good .
Paul .
- woodrat
Re: My First Nylon.
Paul wrote..."But I'm well chuffed with the final result"
....so you aught to be Paul, that's a beautiful result!
Re: My First Nylon.
I like that a lot Paul. Any chance you got some pictures of the internals?
Re: My First Nylon.
I want! What a beauty, I love the colour/wood combinations & the lines are so clean you could cut your fingers on it. Excellent work Paul, if your customer isn't happy with it smack him over the head with the Tele & send this gem to me!
Like Allen, the internals have tweaked my interest so any shots of that would be very much appreciated.
- ozziebluesman
Re: My First Nylon.
Thanks for posting the pics of your guitar Paul. It certainly is a classy looking instrument. I do like the look of the Cyprus and your detail is impecable.
Re: My First Nylon.
Hi Gents,
Thanks for your generous Praise , I have a photographic memory , so It often never Occurs to me to Take Construction photo's , Now after using a makeup compact and a shitty camera I wished I had , So it's the best I can do, Sorry , But I did a Mock up using a MDF template, a "Opps I F#@* that up" soundhole support and a peice of Bracing to give you the concept !!! .
Paul .
Re: My First Nylon.
Congrats on completing such a wonderful guitar Paul . Not often we see a florentine on a classical , but why not ?.
Your Smallman meets Gore bracing set-up looks interesting . Wish I could hear it ,or better still ,play it. Love the wood choices too. Blondes have more fun right ?? Great work Paul.
Craig Lawrence
Re: My First Nylon.
Congrats!
My first thought was: "Cutaway meets soundhole"!
...and: "It looks great"! (of course).
So I think you completed a Mission Impossible!
And here I thought: "I simply would have told him it would be a steel string then"!ozwood wrote:his brief was," I hate the feel of all the Nylon's I have tried, I hate the Look of all the Nylon's I have seen, I want it too feel like a Steel string in terms of the neck , I want it to look different from a Normal Nylon , I want to it to have a Pickup that reproduces the sound of the guitar , not the strings , and I want it to be Cutaway"
Because a a nylon string guitar with a florentine cutaway is not (yet) classical! (It's "only" a nylon string guitar).Craig wrote:Not often we see a florentine on a classical , but why not ?.
Re: My First Nylon.
I totally Agree Markus ,
I have never Called it a Classical , Just a Nylon In fact we should call it a " contempary " I love a Challenge, I'm not Bound by fixed Idea's of what I beleive an Instrument should be, I believe within reason , that It's OK to Push the Boundries, I'm Lucky to be Mentored and support by a builder Like Justin Montifiore, and to have a Muso like the guy that this Instrument is going to , to give me the trust to make an instrument like this .
It is what it is , and my measue of success it the Guy who's Playing it loves it.
Paul .
- christian
Re: My First Nylon.
What a beautiful guitar Paul !!!!
love that you used Cypress, (I think its a really underated tonewood), and that you really pushed the design good on you !!
love the contrast with the binding really crisp clean lines !!!
I wonder if has a Flamenco kinda sound to it?
Christian.
Christian.
Leonardo da Vinci
www.christiandruery.com
Leonardo da Vinci
Re: My First Nylon.
Well having played the guitar the other day, I can say Paul has certainly achieved his design goals on this.
It's a beautiful instrument as you can see.
Playability is fantastic, with the neck width, thickness and action closer to a steel string than to most classicals.
Sound is clear,full and even with a lot of sustain, more classical than flamenco.
Plugged in the sound was very natural, but with enough bite to cut though. definitely no UST twang with the K&K's and could get to quite high levels without feedback.
The new owner should be delighted.
Re: My First Nylon.
Well done Paul
Impressive look and innovative design. The bindings frame out the blonde wood beautifully. I would love to hear what you have accomplished with your Gorogyi fusion bracing.
Re: My First Nylon.
I'll ask the new owner to do a MP3 file of a song , and post the Link when he does .
Paul .
- Beefwood
Re: My First Nylon.
well chuffed indeed Paul
- Tod Gilding
Re: My First Nylon.
What can I say that hasn't been said, magnificent
Congratulations
Congratulations
Users browsing this forum: No registered users and 93 guests
