Page 1 of 1
Belt alignment on jet 10-20.
Posted: Thu Jan 22, 2015 5:20 pm
by ozwood
Hi all,
Took advantage of Jeff's generous offer to source some feed belts in bulk, The old one always track straight, but was getting a bit worse for ware, Put the new one on and now I can't get the Bloody thing to track at all keeps heading to the motor side no matter what I do , I have followed the jet instruction, still no Joy
any advice from the collective wisdom.
Re: Belt alignment on jet 10-20.
Posted: Thu Jan 22, 2015 5:49 pm
by Kev3
Hi Paul,
have you tried flipping the belt around the other way ? If it still rides the same way it may actually be the belt.
I had hassles with brand new belts on a 16-32. No matter what I did it would drift to the outside. Even with one side tight to bursting and the other flapping loose. Checked everything possible - and I mean everything, it was a new sander, so it could have been anything including things mechanically being out of square. Turned out, after a load of back and forth with Carabtec to be the seam on the belt and how it rode over the rollers. Waited for a new batch to be sent from the suppliers and everything ran perfect.
Posted: Thu Jan 22, 2015 7:28 pm
by ozwood
Thanks Kev,
I'll try flipping it around and see what that does !.
Posted: Fri Jan 23, 2015 11:43 am
by Kev3
Hi Paul,
this should be "simple" - it's just a belt going round 'n' round
But they can be twitchy if the tension is not even across the rollers. Given it worked fine before, start with the assumption that the conveyor assembly is OK (not out of square, bushings for rollers binding etc). If you haven't done anything yet, try and loosen the tensioning bolts by the same amount each side - just enough to get the belt off - that should keep the assembly roughly similar when you flip the belt around. Don't know how you've got the whole sander mounted, but be careful when bolting the conveyor assembly back up you don't inadvertently put any twist/skew into the framing.
Posted: Fri Jan 23, 2015 7:37 pm
by ozwood
Hi Kev,
That could have happened as well, will Take all that on Board and have a fresh go at it Tommorow.
Thanks again for all your help.
