Jointrookie Whimsy T1
Posted: Tue May 27, 2014 10:01 pm
Hello all,
I'm a relatively newbie to the world of woodworking, picking up the hobby last year. I am not a luthier, but I am from Australia, so thats half the qualifications for the forum, right?
Diving into the vast amount of content online, youtube in particular, eventually I stumbled across the Jointmaker Pro and then laughed heartily when I saw the money they wanted to charge for it. It was something I really badly wanted, but not at that expense. Eventually I stumbled across Marcus' (charangohabsburg) Jointapprentice Hobby A1 that he made a few years back.
I've now developed my skills enough that I could actually build that! Speaking with Marcus about it though, he didn't have any plans drawn up. I've decided that I will draw up some plans (sketchup) and make those freely available once I've finished the build (can't have anybody beating me to the punch! or more accurately, things might change as I break/fail).
Once all said and done, there will be a build video on my youtube channel, but for now bear with me as I spam a build log at you!
I'm going to do a few things a little different from Marcus - I'm opting for an 'easier' table build by going for the more expensive option, steel shaft with linear, rather than drawer slides. This is a personal preference, but a secret reason is that eventually I may build a CNC router and getting to play with those sorts of parts is a good excuse.
Secondly looking at the 'height limitation' of the Jointapprentice, I'm going for gears to lower/raise the blade assembly. I'm benefiting from Marcus' research where he found the patents that show how the JMP uses gears for that. I think the wedge system is the cause of the limitation, and a steeper angle or much longer wedge is needed to increase the vertical travel (somebody correct me on this one!).
Parts
Other than screws, bolts, threaded rod, glue, MDF, ply and hardwood (tas oak is suitable, although if I find jarrah/blackwood offcuts the right size they'll make it in), below is the proposed parts list
2 x 16mm x 700mm hardened chromed shaft
4 x SC16UU linear bearings with pillowblock housing. I would have gone for just the bearings, LM16UU, but the same store had both the shaft and ONLY those bearings.
1 x Razorsaw Kataba 06 Super-Hard 240mm. I already had/have this, as its the brand of dozuki/kataba/ryoba that I use. Saves me from waiting for it from japan.
1 x nylon chopping board (used, but clean) for gears
Without a doubt, the bearings and hardened rod are the most expensive part, but when you consider to get the JMP to Australia including a fence (because why bother otherwise?) you're looking at over $2900 (US->AUD+Shipping), I don't mind spending ~$70 on "better than Bunnings draw slides".
Approach
The way I see it, this project can be broken down into two main parts, the blade assembly and "everything else". Naturally - for me - I'm going to start this the wrong way around and tomorrow I'm going to whip up a very basic table and "carcass" to house it all in. I'm probably not able to get to the finer details until next week, so chopping up some chipboard and painted MDF that is already on the "to bin pile" and adding some 16mm holes isn't going to be too stressful!
Parts
Approach
