Cheap Nut Files
Posted: Sat Dec 18, 2010 8:14 am
Hi All,
I just wanted to share what I have been using to do my string slots.
All you need is a feeler gauge and a Dremel with a fine grinder blade. Basically you are just turning your feeler gauge into a file, you will get a range of thickness for about $10
I round the bottom edge of the selected gauge with a file and sandpaper.
Then grind slots into the edge of the gauge at a slight angle. I like to leave the burr it helps to cut the material. It also give a slight tolerance so you can match you string diameter to the thickness of the feeler gauge and string won't be tight in the slot.
