Bending Black Limba
- Beefwood
Bending Black Limba
Hi to all,
The two main factors I work with when choosing Sides and Backs for my guitars (they are all gifts for friends and family) are cost and aesthetics, I recently puchased some amazing looking Black Limba but cannot get the sides to bend without splitting.
I have tried both hand and machine bending.
I spritz the sides thoroughly beforehand.
I thin sides to 2.2 mm thickness.
Has anyone, with Black Limba experience, got any tips or tricks that may help please.
- lamanoditrento
Re: Bending Black Limba
2.2mm is a bit thick in my book. I start everything at 2mm and then will thin out troublesome areas or high figure wood further. 1.8mm for a Venetian cutaway or even waist areas if the wood looks a bit antagonistic.
2.2mm is a bit thick. My sides are a maximum of 2mm...thinner where I'm bending around a tight radius. Parts of the side that need to be thinned to facilitate bending can be reinforced if necessary with internal patches once the side is bent up.
Splitting along the grain or snapping across the grain?Redbloke1956 wrote: ↑Sun Mar 06, 2022 4:55 pmHi to all,
- Steve.Toscano
I've bent quite a bit of black limba as i went through a phase useing it several years back.
Dont remember having any real difficulties with it breaking out or splitting. Although I do remember that it doesnt like to hold its shape very well post bending.
I typically leave my sides thicker too - around 2.2 - 2.4, and in most cases soak for at least 15mins.
All hand bent.
Like others have mentioned though, try taking it down to say 1.9mm.
You might just have a piece with a lot of grain run out, in this case you might have to ditch it.
If bending by hand try a slat of spring steel behind the bend to avoid it splitting out.
All hand bent.
- Beefwood
Thanks for all the replies,
To nkforster the splitting is at the waist and is across the grain, on my second attempt I soaked the timber for probably 10 minutes, while machine bending there was no audible crack so my hopes were up …initially.
Tomorrow I will attempt a bend at 1.9mm and see how it goes.
Thanks again to all for the input
Kev
Kev
A few questions:Redbloke1956 wrote: ↑Sun Mar 06, 2022 10:14 pmThanks for all the replies,
Kev
- how are you bending the wood? By hand on an iron or on a form with a silicon blanket?
- how hot is your iron/blanket?
- are you supporting the wood on the outside of the bend with a slat or similar?
- is the wood quarter sawn or off the quarter?
- Beefwood
Hi Martin,
I have tried hand bending with a bending iron, I have tried bending on a bending machine/former with a steel slat on each side of the timber and silicone heater.
The heater was at 165 degrees C
So they are snapping. Common enough.
This applies to any woods that are hard to bend -
Soak in hot water, mix in half a cup of any white fabric softener, weight the sides down and leave for 20 mins. Then bend.
Users browsing this forum: No registered users and 240 guests
