first inlay attempt
- Wandoo
first inlay attempt
Hi All,
I am half way through my first inlay MOP in a chopping board for the next Aus Barista Championship. I have a few questions there are a few gaps between the MOP and board and to fill I mix sanding dust with the epoxy right? but I am going to stain the board to improve the contrast it is going to be a dark rosewood/black mix do I stain before I glue in the inlay? how do I stain the filler saw dust?
I suppose there are various ways of going about this. You could use a dye in the epoxy to get the desired color. I have a selection of Color Tone ones from Stew Mac. I've done this a few times and works great. Saw dust works really good with ebony, but on other woods, the mixture always seems to come out much darker than the the surrounding wood. This could work to your advantage if your going to stain it darker.
It's probably worth trying this out on a piece of scrap to see what it's going to look like before you commit. Cut a slot in a bit of scrap, make up some sawdust / epoxy and fill, then sand back and see what color you get. Try out some stain and you'll get your answer. If the gaps are fairly small, like they appear to be, you should be hard pressed to see them if the color is close.
I think that I would be staining the board after you have inlayed the pearl and sanded it all level. Otherwise the stain is going to get into the end grain where you've routed for the inlay and make that much darker. You will also end up sanding a bit of the surface to level out the epoxy and inlay, so will likely screw up the stained wood somewhat.
Be sure to post a picture of the completed project. Nice design so far.
- Taffy Evans
Hi Craig
I agree with Allens comments. For me inlaying into lighter coloured timber is a slower procedure to get as close a perfect fit as possible,not always achievable. Even on ebony I try for perfect fits. What I do is route out up to the outline [ but the pearl does not fully fit] then I put a suitable round dental burr in my Dremal and using the shaft as a guide against the edge's of the outline I undercut around the design. I can then make very small controlled cuts to the thin area of wood up to the scribed line with a sharp knife or a specialy modified 1/16 inch chisel. When the inlay is pressed into the recess the epoxy fills any unercut thats left. I'm talking small amounts here.
Heres a picture of my next inlay, it's abalone and just layed out to get a good balance, two legs to go and the engraving.
The other picture is of the inlay work on a Gibson Mastertone Banjo, not a cheep little sucker, ya gotta do better than that. Well looks like you have already.
- Wandoo
Hi Allan and Taffy,
Thanks for the help and advice, Taffy I should have left the final routing fit for another day, I rushed and there are a few gaps, nothing more than 1mm but still I know I could have done better. I have 3 more duplicates to do so I am hoping they get better and better. Photo updates to continue.
- Wandoo
- Wandoo
- Wandoo
- Wandoo
Craig,
I reckon your patterns are brilliant, there beauty would see me hesitant to drink the coffee...but not for long, I just love gooood coffee.
- Wandoo
- Wandoo
Users browsing this forum: No registered users and 277 guests
