Binding Glue
Binding Glue
Hi Folks,
a genuine question, but also wanted to unlurk myself
I have some plastic bindings for a mountain dulcimer and need to get them on within two weeks.
I think I've left my run a bit late for a mail order adhesive?
Any recommendations? - Cheers
Re: Binding Glue
Selleys plastic glue available from Coles, Have used it several times myself.
A wipe on primer you use first then the adhesive.
Re: Binding Glue
Check out your local hobby/model shop. They have a plastic glue which smells identical to Weldon and will stick plastic to wood.
Miguel
Miguel
- ozziebluesman
Re: Binding Glue
Tarzan's grip has worked fine for me for gluing plastic to wood.
Very cheap at Bunnies.
Re: Binding Glue
+1 on the Tarzan's grip
- Steve.Toscano
Re: Binding Glue
+2 on tarzans grip
- rocket
Re: Binding Glue
Weldon 16 by online order delivery time,, cuppla dayz
Re: Binding Glue
personally I like CA gel. Used Weldon a few times and didn't bond with it even bought a couple of large tubes which I bought at a plastics place out Braeside way. It still sits unopened in a drawer in the workshop/
The CA can be a little challenging at first and after you glue your fingers to the job a couple times you learn that less is more. A little dab'll dou'ya. It setups up nice and quick but not too quick [30 secs] so you dont have to pile on the masking tape.
With a bottle of zap yellow, some catalyst, spatula and some acetone I can get the binding on, set hard and cleaned up in one go.
whoever spots the product placement quote can have the Weldon
Re: Binding Glue
Hi Old_Picker is it:
for Brylcream?
I'm in my late fifties and remember Brylcream was a household name around the country:-)
Cheers - Pat
(now de-lurked and grateful for the replies)
for Brylcream?
Cheers - Pat
Re: Binding Glue
I buy my Weldon from a local Perspex place. Cheaper than buying online too. Try a couple of your local plastic suppliers.
Re: Binding Glue
Californian Poppy for me Pat.
Re: Binding Glue
Hi Steve,
yes, I recall California Poppy also. Dad's bottle was shared with the boys on special occasions
back to the topic.........
Rather than plastic bindings, I have some of that black/white/black purfling.
It's around 3mm x 1mm
Can anyone see a problem with me stacking two of those to make a 6mm x 1mm and using titebond?
It's a tear-drop dulcimer so the curve is quite gentle?
Users browsing this forum: Google and 247 guests
