"Originally Posted on:Sat Jan 09, 2010"
Hi everyone,
Here is a question for the electric builders.
What is a drop top and in which electric guitar design would it be used?
Please correst me if I'm wrong but I think a 1/4" book matched or one piece cap is for decorative purposes and the 3/4" is extra material so the top can be carved with a dome.
In the near future I am considering building a Les Paul Junior style electric for myself. I want to use soap bar pickups for a big fat tone and incorporate the light weight of the junior.
All discussion and thoughts greatly received.
Cap, Drop Top, Carved top?
- ozziebluesman
Re: Cap, Drop Top, Carved top?
Alan, my understanding of a drop top is that its a guitar that has a cap of a different wood, usually something visually interesting, like curly maple. The under body is usually something like alder. It usually thicker than a veneer, in some cases thick enough to carve contours on without going through it.
Using a drop top gives you the visual appeal without the weight and the expense. I don't see why it can't be used on any style really. You can use it to cover the under body when you chamber it to lose some if its heft. You could carve a Les Paul with one, as long as its thicker than your contours.
A "drop top" generally refers to a thinner top used on a basically flat top design (sometimes bent for forearm cut) rather than the thicker top used for a carvetop.
A junior typically does not have a cap but there is nothing to stop you using one.
My '59 LPJ replica is built from solid brazilian mahogany. with one dogear P90 at the bridge
Love the sound and the easy access to the end of the fretboard.
If you are thinking 2 soapbars you will need to do a little modification to the junior design to avoid cutting away all the neck tenon for the neck pickup (raising fingerboard level like a LP special)
Anyhow, it was a few years back but I can help you with the details anf pitfals so just ask.
regards
Jeff
regards
Jeff
- ozziebluesman
Lillian: Thanks, you have clarified things nicely. So a drop top is used for semi hollow electric designs like the Tele thinline? I like the idea of carving a contour on the top also! A challange there I reckon!
Jeff: G'day mate! Yep I remember your Junior build and still have the pics you sent me. When the time comes I will contact you for some good advice. Thanks for your input.
A drop top can be used on any guitar. From my experience they're usually 3/8" thick, but are sometimes 1/4" thick.
They are used on hollow bodies, but it doesn't have to be a hollow body or f-hole to use one.
but a LPJ with a carved top is a PRS
