Progress pictures of my Fat Bottom Girl
I've had a bit of a productive weekend. Made some bindings and purflings, Inlaid the end graft, bound the body and sanded it out. This is the first time I've done a sound port, so I thought I would give it an Australian feel. I cut it before I bent the side, but I think that if I was to do it again I would cut it after. I thought that I had put it in the center of the side, but as you can see, I got the measurements a little off. Live and learn.
This is also the first time that I feathered out the lower X-Braces before they reached the linings. The top braces are some perfectly quartered red cedar that is really stiff. The top rings much more than any guitar that I've built yet. Also much lighter too. The body as it is comes in at 834 grams.
Back and Sides African Mahogany
Top, Redwood
Bindings, Queensland Walnut
Purflings, just some black and white veneer sheets that I slice up with a scalpel.
Top, Redwood
- Dave White
Allen,
That looks nice so far. The Queensland walnut looks like ebony in the pictures - nice. The African mahogany looks good too. I've just got some long sets in ready to make a double-necked Weissenborn-style acoustic lap slide.
Dave White
- Dave Anderson
Then I've got all sorts of innovations happening on my guitarsHesh1956 wrote:Oh, Luthiers never use the word "mistake" and instead replace it with the word "innovation."
There are two types of Queensland Walnut. The more common one is lighter colored and more variation in tone. This one is a really deep chocolate brown. I got 3 full sets of the stuff that are full 900mm X 210mm wide. So lots left over for bindings, bridge plates etc. I've never built with it, but the next one is going to be walnut/engelman.
- Ron Wisdom
You have a great eye for style Allen, that looks great, and like that big bum design as well. I am also really taken with that darker form of QLD Walnut. I understand that Maton use that wood but only as a laminate, and some suggest that they do this because it is a bear to bend. How did you find it??
I first spotted that style of back stripe on Mario's build site. It wasn't very clear in his pictures, but I liked the idea very much for something a little different, so I suited it to my building style and match the curve into the end graft...at least I try too.Ron Wisdom wrote:Allen, I like that very much. Love the back stripe(s). That's the first time I've seen that done. Nice!
Ron
I give him full credit for the design and call it the" Proulx Back Stripe".
The walnut is really hard, but surprisingly not that heavy, at least compared to some of the other local hard woods. The pieces that I have are really nicely 1/4rd and I've sawn them out to about 10mm thick. The problem for making them into bindings though is that the strips end up being flat sawn and that gave me more problems than anything with bending. I just misted them and put them to the bending iron. Took it easy, and only broke one strip.Kim wrote:...I understand that Maton use that wood but only as a laminate, and some suggest that they do this because it is a bear to bend. How did you find it??
They were really thin and I imagine that helped a lot. I suspect that the sides are going to be a bit of a chore. I'm going to have to get myself a silicon blanket to tackle those I think.
That is so cool Allen . I would never pick the rosette as a recovery from a dyslexic moment. In fact ,I really really like it the way it has turned out. Is that Paua ? Great colouring. The walnut colour looks wonderful too, and what you have done to the back strip and tail wedge is very impressive .
Bravo Allen !
Cheers Craig
Bravo Allen !
Cheers Craig
- Dennis Leahy
Yes, Paua. I get it from MOP Supplies. As well as the MOP nut's and saddles I've been using. I've got some Paua notched squares that I plan on using for fret markers if the color doesn't clash when I get to that point.Craig L wrote:... Is that Puau ? Great colouring. The walnut colour looks wonderful too, and what you have done to the back strip and tail wedge is very impressive .
Bravo Allen !
Cheers Craig
Users browsing this forum: No registered users and 269 guests
