binding jig of sorts
I thought I'd introduce myself and introduce my makeshift binding jig as well. ....production costs have blown out to a whopping $4.60 for the 2 bearings.....the rest is what I could find lying around..hopefully it will be stable enough.
Based on the Jim Williams jig with the addition of the washer which I saw on Arnt Rians Jig..Where as Jims jig has a wide footprint gliding on the top I have made this so the only thing that touches the top is the washer...
I haven't tested it yet but have run it around the top unpowered and can't see where it can go to much wrong? but I may be wrong.. time to try it on some scrap and see if it works.
Anyway I'm Grant.
Thanks for looking
Anyway I'm Grant.
Thanks for looking
Nice looking jig their Grant. Youre going to get the same result as I will with my soon to arrive $US195 Luthier Tools binding cutter base for a lot less. The washer is a clever addition.
Some tips:
1. Make sure both the bearings are riding against the side of the guitar.
2. Check that youre not tilting the jig forward or back as you make your cut.
3. make your cuts in several passes.
4. watch direction you run the router and jig to minimise tear out. See Stewmacs website and notes on their binding cutting bearing set for guide to direction of cut.
5. ALWAYS do a test cut on scrap and test fit your binding or purfling. Dont ask me how I know this!
Cheers Martin
Some tips:
Cheers Martin
Welcome to the forum Grant.
Good looking jig. Hope that it works out as planned. I love to see things people make without have to spend heaps of cash.
As Martin says, watch what direction you are going. When I'm about to route a top I always take some white chalk and draw arrows on the top and back to remind me of the direction to route in. It makes it a no brainer when you are concentrating on getting that ledge just right. The fewer things that you have to think about the better .
Hey, that looks familiar! Good job, your jig should work well.
Martin has some good suggestions, here are a couple of additional thoughts:
In your jig, the movable 'shoe' (the vertical plywood part that the bearings are attached to) has a pretty small contact area with the horizontal plywood base plate. I would be concerned that this joint might not be rigid enough, and that the two parts could flex a bit and not remain square in relation to each other, possibly leading to an non square binding rabbet.
I prefer to use a down cut spiral bit, I think it cuts cleaner than a straight bit. I use 1/4" carbide down cut bits from LMI, but you may find them less expensively locally.
I have had better luck by placing the jig horizontally in a vise and feeding the guitar to the tool than using it hand held, which feels a bit unstable to me. This may sound scary to some, but this principle is used in many of the big guitar production factories (Martin, Taylor), and I feel it gives better control over the process.
To avoid blowouts, I cut from the widest parts of the bouts towards the waist, then towards the blocks, and finally a single pass around the entire instrument.
Consider recessing those screw heads in your base plate; they could easily ding a soft spruce top should they come in contact with it...
Good luck!
Good luck!
Arnt Rian,
Norway
Norway
Arnt, You hit the nail on the head ...these are exactly my concerns.. I may even make another where the joint between vertical and horizontal is bigger. And I think I'll make the base a bit thicker also which will allow me to recess the screws...
Bob, The box is all closed up now ..I just have to hardblock the sides a bit before binding..I will post some pics of the body ..I'm pretty happy with it so far and has a nice sustaining deepish note to it when tapped..hopefully that means I'm on the right tram.
Martin, cheers for the tips,. you don't have to elaborate on tip #5 if you don't want.. the washer is all Arnt's genius by the way...thanks Arnt your base looks very nice
Allen, I like the challenge of trying to work out how to make a jig work ...Its quite rewarding...I think this will just be a prototype for another version over the next week or so.....as it only took an hour or 2...
Welcome Grant!!!!
That is a great looking jig and the guys here have given you some great advice.
You will need to make something to hold the guitar body firmly in place and it will need to be fairly low so the jig does not hit it but then you will be good to go.
I second the tip on getting Stew-Mac's climb cut diagram and taping it on the wall. I use that thing every time I route for bindings and have never had a blow out.
Good to see you here Grant.
thanks Hesh...good to see you here also...and i just noticed you have a website up now which looks very nice...I've just been ogling those beautiful pieces of yours..
as for holding the body..
i was thinking the left elbow might be something good to hold the guitar body with?
no seriously....the first sanding dish I made turned out to be about 23' so it got scrapped and I made another one @28' for the top....but it might come in handy if i drill some holes in it for some dowel to hold the body in place?
I've actually made another router base last night ...Mark2
with all the suggestions talked about earlier....Its a lot more rigid
I'll post some pics ...when i finish it off
This one feels more stable.....just needs a few minor adjustments and I need to test it out on some scrap ..
Maybe the front of the washer should be on an angle ?...I'll look at this on the guitar and see if its riding up or tilting with the arch...
and I noticed that because the base is now thicker the locking nut on the collet needs to go into the base a few mm's to get the cutter depth...
- Graham W
- Kauri
Hi Grant
What are you mounting the jig on? - router, laminate trimmer, dremel…?
Or would it work on any of these?
It looks to be a simple solution to what I have found to be one of the most difficult operations in guitar making. I'll be very interested to read how your jig performs.
Please try it on scrap wood first!
Graham
Graham
Graham Wardrop
PO Box 18 845
Christchurch 8641
New Zealand
guit.art@clear.net.nz
PO Box 18 845
Christchurch 8641
New Zealand
Re: binding jig of sorts
Graham,Graham W wrote:Hi Grant
Graham
Its mounted to a laminate trimmer....I'll report how its working out..
Grant
- Ron Wisdom
- Graham W
- Kauri
hi Hesh
That's a very serious looking set up you have there. If you saw my tiny workshop space you'd know why I have to look at something smaller, although ideally I'd have a set up like yours. Did you build it from available plans or did you work it all out yourself?
All the best to you - your work looks fantastic!
Graham
Graham
Graham Wardrop
PO Box 18 845
Christchurch 8641
New Zealand
PO Box 18 845
Christchurch 8641
New Zealand
I really appreciate the help....Its great to see your jig...I really like the way how it adjusts for thickness of binding.Craig L wrote:I'm with Paul on this one . I have my left hand on the unit as a guide whilst moving it around . Go slow , and keep the concentration going.
Please don't think I am trying to overshadow your thread here with my binding jig thread. Just thought it maybe helpful to yourself and Graham W
Cheers, Craig
Here's mine. Most of the time it's stored under some of the other clutter. I just dug it out to show you my set up. The guitar is clamped in a cradle and the trimer is run around the perimeter. I use a Cutter with bearings. You could also mount it permanently to the wall if that's an option for you.
It's pretty well a no brainer and changed one of the most frightening parts of building for me into one I look forward to.
It's built from some unknown species of local hardwood that I found in the tip shop. I think that they were slats from a bed frame from under the matress. The pivots are just 1/4" steel rod pounded into a really snug whole. Works for hard wood, but wouldn't be acceptable in soft wood. And then some 1'2" threaded rod for the other bits. Some scrap perspex from the tip shop as well for the trimmer mount. The base plate that I use is some walnut that I knocked together. You could use almost any type of set up for this. If I had of thought of the large steel washer I probably would have done that.
The whole thing didn't cost more than 10 bucks, and that is including the stubbies that it took to lubricate me....I mean wash down the dust. It' gets awfully hot up here
Users browsing this forum: No registered users and 246 guests
