Hi all, I'm interested to hear people's experiences with different wood species for acoustic bracing, either falcate, x bracing or other traditional patterns.
In particular, I'd love to hear how Australian natives work for bracing, such as bunya, King Billy pine, Australian red cedar etc, and also from anyone who's used hardwoods for back (or other) braces.
If you're using traditional spruce or cedar, what variety and why?
Different bracing wood species
Re: Different bracing wood species
I've always stuck to spruce..light and stiff.
King Billy pine...only wood that Ive actually tested for stiffness. The stuff is si variable its risky using it without testing actual stiffness.
- TomBicknell
Do you know if there's any visual indicators of stiffness with King Billy, Martin? Apart, of course, from the obvious quartersawn grain, free of knots etc.
I've always followed the advice to make sure the grain direction of the spruce is vertical relative to soundboard.
When I knock up a batch of braces I take a blank 8mm x 12mm x 50mm and subject it to deflection testing with a 1Kg weight on the end, its remarkable how much variation there can be between batons.
More recently I have tended to cut the blanks into 2.7mm x 12mm strips and then laminate three together, usually turning the middle laminate upside down to give a slightly different grain orientation. I find this gives more consistent results in deflection tests. I have even taken to using a different wood, western red cedar, as the core, but this is just for prettiness.
I laminate whether for both Falcate and straight braces.
Peregrine Guitars
Peregrine Guitars
- TomBicknell
Do you have a preference for a particular species of spruce, Alan?
- peter.coombe
You left out Red Spruce, i.e. Adirondack Spruce.
- TomBicknell
Oh yes, my bad! Not sure if I can edit the poll without losing everyone's votes - Martin?
Users browsing this forum: No registered users and 550 guests
