Walnut bend
mac007
Walnut bend
Post by mac007 » Thu Mar 14, 2024 6:38 pm
Hi
So this is the first time I tried walnut (straight grained) and for supposedly easy bend -it didn't work.
The first sandwich was spritz water, paper, foil heat blanket and iron strap. Has worked well before.
Heat blanket to 176 deg/off then start clamping.
Heat OFF.
Clamp waist then roll sides.
Cracked after cooldown.
2nd attempt-
More water sloshing the panel with a rag ie more water.
Better but still cracking.
I have enough for one more go.
Any suggestions appreciated
MK
Online
Re: Walnut bend
Post by kiwigeo » Thu Mar 14, 2024 6:53 pm
First question..how thick is that side?
When I was using blankets and forms for my bending I used to start the waist bend on a bending iron before sticking it in the bender.
These days I bend by hand. Im old fashioned and enjoy being in constant contact with the wood as it bends.
mac007
Re: Walnut bend
Post by mac007 » Thu Mar 14, 2024 6:59 pm
Thanks Martin
1.8mm as per TG
But I hear what you say and I'm thinking I'll start on an iron where you can get a 'feel'
Ken Parker does a similar thing in his archtop vids.
Cranking down on a bender doesn't provide much feedback.
Chrs
MK
Dave M
Re: Walnut bend
Post by Dave M » Thu Mar 14, 2024 9:58 pm
This is not going to help much but I found my American Walnut behaved fine. However I have a bender that keeps tension on both sides of the timber enabling that fairly tight cutaway. I am at around 1.8 mm and bend at about 120 C. Reasonably damp but not soaking.
Good luck D
mac007
Re: Walnut bend
Post by mac007 » Fri Mar 15, 2024 7:54 am
Maybe some fabric softener???
Anyone had experience with this?
MK
Online
Re: Walnut bend
Post by kiwigeo » Fri Mar 15, 2024 9:30 am
MK
Ive used supersoft on tight bends.....it helps.
Re: Walnut bend
Post by 56nortondomy » Fri Mar 15, 2024 4:25 pm
I find walnut bends easy, I thickness to 2mm, at the cutaway section it's about 1.8mm I always use fabric softener. Cutaway sides I soak in hot water with fabric softener for about 25 minutes. Non cutaway I just spray with water and bend, I use aluminium slats for bending. Make sure your blanket is up to temperature before you start to bend. I bend at around 250f to 300f deg. Wayne
Re: Walnut bend
Post by Taffy Evans » Sat Mar 16, 2024 8:57 am
Hi, I have bent Walnut without issue, but then I have had mahogany slit on me.
I use the same sandwich setup but with a different heat source. I have heat bulbs in my bender heating from under the side pack with a blanket on the top of the pack under the top slat. I will also apply pre-heat to the waist area of the pack with my heat gun. I slowly add pressure to the waist, allowing the side to gain some heat from both sides. I stop before the waist bottoms out and work on the sides. when they are bent I complete the small amount of waist bend. Oh, and at times I have used a Veneer Softener spray but normally just water. I time my bending session so I can leave sides in the bender overnight.
This possibly will not help.
Cheers Taff
mac007
Re: Walnut bend
Post by mac007 » Sat Mar 16, 2024 12:18 pm
Thanks for all the replies- some interesting suggestions which I will try.
1/ Use an iron for the sharp shoulders
2/ try fabric softener
3/ Bend the outside curves first, then the waist
I have one piece to practice on then my last 2 sides of walnut.
I also feel that we (at my club) tend to bend the outside shoulder curves a bit too quickly- but then I have seen vids where people just pull the spring loaded cauls pretty much straight down as soon as the temp hits target.
Thanks again
MK
Re: Walnut bend
Post by Taffy Evans » Sat Mar 16, 2024 1:35 pm
Hi again, I just came across these pics.
After the first failure, see the front side, I did what is seen in the next pic. To get the perfect bend out of the second set I wrapped the whole sandwich in foil as well. This pic shows the sides just taken out of the mould.
I did not waste the damaged side I made a thin-body acoustic.
But that's another story...
mac007
Re: Walnut bend
Post by mac007 » Sat Mar 16, 2024 4:06 pm
Thanks Taffy,
Yeah we routinely wrap foil/paper/wood.
I like your system of heating both sides tho'
MK
Re: Walnut bend
Post by Mark McLean » Sat Mar 16, 2024 9:40 pm
Walnut usually bends easily. 1.8 mm is pretty thin, so should not fight you too much. Maybe that is just a difficult piece of wood?
WJ Guitars
Re: Walnut bend
Post by WJ Guitars » Sat Mar 16, 2024 10:16 pm
When I bend sides on my bending machine generally temperature is set around 280 to 300 degrees F. Once the side bend is completed I reset the temperature controller to 260 degrees F and let it cook for 15 minutes. Then I switch the temperature control off and let it cool down to room temperature before removing the side bend from the machine. I found this method from a 'Blue Creek Guitars' YouTube on bending sides. So far I have had no cracking problems with when bending a vast range of of timbers including walnut using this procedure.
Users browsing this forum: No registered users and 266 guests
