My first build: a fretless ABG
TrevorMag
Post by TrevorMag » Sun Dec 20, 2020 2:37 pm
Design
I wanted to use A-frame bracing design with asymmetric soundhole, and carefully analysed the shape of four such instruments:
  • Tacoma Thunderchief CB10 - regarded as one of the best production acoustic basses, sadly no longer being made
  • Furch B61-CM - a very attractive design. This is a Czech brand, sold in America as Stonebridge, in Germany as Standford
  • Boulder Creek acoustic bass range.
  • Warwick Rockbass Alien.
I compared upper/lower bout ratios, waist height, waist depth, cutaway curves, squareness v. roundness, and came up with a design that I felt combined all the attractive aesthetic elements of those guitars, while avoiding aspects that didn't appeal to me as much.
I also came up with a wave motif that I wanted to use for the headstock, bridge and fingerboard end.
For a number of years I built jigs, molds, woodworking equiment, and practiced the craft with less demanding projects. At the beginning of 2020 I decided it was time to jump in.
I chose to make a fretless as my first build for a number of reasons:
  • Less precision regarding intonation
  • Less precision regarding fretboard straightness / action / relief
  • I wanted a fretless.
Disasterpiece
My preparation was to watch a series of DVDs on guitar building, plus a few YouTube videos and various forum posts.
I had no mentor during the build, and managed to make just about every mistake it is possible to make, plus a few that you might think aren't possible.
Each of these has been meticulously written down, and I believe that if I press on and build another, it'll be a much smoother ride.
Cutting the neck scarf joint with a jig on my (self-adapted) table saw
Neck pieces glued up
Cutting the truss rod slot in the neck using another jig
Cradle to hold the fingerboard blank for cutting bevels
Cutting bevels in the fingerboard prior to sanding in the radius
Neck and fingerboard components
Neck after initial shaping
Pantograph jig for Dremel, reduces the template by one third, for headstock inlay channel
Headstock inlay
Sides milled
Bending the sides in a Fox bender
Bending the cutaway curve
Sides bent, ready to be laminated
Laminating the sides
In the mold
Gluing tail block
Gluing neck block
Neck with headstock veneer
Jig for making kerfed linings. This is hazardous! Think I need a bandsaw!
Kerfed linings
Gluing in the kerfed linings
Kerfed linings done
Butt-joining the book-matched pieces of the soundboard
Soundboard and back after butt-goining
Glueing the bracing to the soundboard and back
Soundboard and back with bracing
Attaching the back
Side braces
TrevorMag
Re: My first build: a fretless ABG
Post by TrevorMag » Sun Dec 20, 2020 2:51 pm
Part two
Attaching the soundboard
Soundboard attached
Back attached
A disaster with the router opening the access port
Partial recovery from said disaster
Binding channels - back
Binding channels - front
Access port fitted, bindings bent
Attaching the bindings
Bindings attached
Soundhole cut
Shimmed and bevelled tongue for neck fit
Gluing on the neck - gravity clamping - next time I think I'll use furniture-bolt clamping
Trimming the fingerboard
Gluing the fingerboard
Shaping the bridge
Attaching the bridge
Taped up ready for finishing
First round of French polishing
The most idiotic mistake yet - pickup jack on the wrong side...
Cover up
Gluing in the pickup
Drilling and supergluing the side marker dots
Side marker dots after cleaning up
Lowering the bridge. I am aware that this is not typically done at this stage of a build
There was a tiny backbow in the neck, but because I used Tassie oak, string tension was not enough to draw it out. Here is how you are supposed to fix this.
Heat lamps and string tensions not nearly enough. Here is how I ended up getting any relief at all!
TrevorMag
Post by TrevorMag » Sun Dec 20, 2020 2:55 pm
The final result
You can hear a rough'n'ready demo on YouTube at https://www.youtube.com/watch?v=Rbtcs1e2xEU
Here are a few shots:
Post by kiwigeo » Sun Dec 20, 2020 4:24 pm
I don't see any major gaffs....the access hatch cover will do what its supposed to do...cover anything underneath it. The jack...well yes that counts as a gaff......but then again I once glued a neck block onto the TOP of the neck. All in all pretty impressive for a first build and also without a bandsaw and a few other tools and machinery most of us have.
Post by 56nortondomy » Sun Dec 20, 2020 6:09 pm
Don't be too hard on yourself Trevor, we all make mistakes, anyway the end result looks good.
Post by Mark McLean » Mon Dec 21, 2020 4:28 pm
Nice job. You did your research, adapted the design, executed the plan, and learned a lot along the way. A great first build.
