Glueing struts RH
Dave M
Glueing struts RH
Post by Dave M » Thu Nov 16, 2017 9:15 am
I was glueing the ladder bracing to a back today when this little niggle that has been around in the brain came back. I have kept the RH down for a few days as per what every serious maker says.
However. If you are using a water based glue such as Titebond, as soon as that liquid hits the great wide board of top or back, isn't it going to pretty quickly absorb that moisture and expand in short order, therefore negating the drying that we have organised? That wetness is going to be around for several minutes I would guess. How long does the timber we use take to expand?
I am talking theoretically but I wonder if anyone has actually looked at what happens when a 10 mm strip of a top or back is wetted with glue across the grain. Does it expand within the time frame of the drying time of the glue?
I do realise that the rest of the board remains dry but is that enough to constrain the possible expansion around that wet strip?
Yours probably overthinking...
Re: Glueing struts RH
Post by Trevor Gore » Thu Nov 16, 2017 9:35 am
Best to work practically... :)
Years of practical experience by many, many, luthiers says "Yes". Soaking the board during glue cleanup could be a different matter.
I've used epoxy on lots of boards and Titebond on lots of boards. Can't say I've noticed any practical difference in outcome.
To misquote a famous marketing slogan..."Just glue it". :mrgreen:
Users browsing this forum: No registered users and 213 guests
