Buffing
Buffing
http://www.mirwa.com.au/HTS_Buff.html
This one may be different for everyone here, but this is my process
Re: Buffing
Forgot photos, from this
to this
to this
Re: Buffing
Great tutorial Steve. The pictorial walk-through really gives a good instruction in the whole process. Do you pre-soak the paper for the wet sanding? If so, for how long?
Thanks, Mark
Thanks, Mark
Re: Buffing
I put some thin craft felt between the block and paper helps to stop the pick up .
Re: Buffing
Thanks,
I'm actually not a pre-soak the grit person, I do u dersatnd the merits of doing that, but time is always of the essence.
That differs when I am using micro fibre pads, these I will pre-soak as I appear to get a better result.
Yes sanding the neck is so easy to go through the finish, I use a rubber backing caul with my sandpaper
Thanks for the positive feedback
Users browsing this forum: Google and 280 guests
