Hi all,, i'm just starting a project at the moment that is a 16inch full body arch top, using WRC, wow much lighter than your common garden variety Sitka,, so i believe with cedar and also King billy the soundboard should be a tad thicker say, 20% ? but as far as the bracing goes seeing as the top is so light i don't want my bracing to be too heavy and i know that the load is going to be just the same , so i'm thinking a slightly lighter bracing set up along with a carbon fibre tow to add some extra stiffness without the bulk of my standard bracing for this type of instrument.
Any opinions offered here will be gratefully received .
Have a great Easter!!
Cheers.
Archtops and carbon fibre
- rocket
Re: Archtops and carbon fibre
I've got no experience with arch tops and no experience with Carbon fibre so take my comments with that in mind. On a flat top I always brace WRC with sitka. WRC is not only light but not as stiff as Sitka.. YES it certainly needs to be thicker on a flatop I tend to 15 -20 % thicker but that of course varies with each piece of wood...
One other thing WRC dents EASILY!!...
I'm sure more experienced than me will have comments..
Kerry
Kerry
KLW Strings Luthier Blog...
http://klwstrings.blogspot.ca/
