Good bye go bar?
- TimS
- ANZLF Approved Supplier
Good bye go bar?
Just some food for thought!
Jig assembly not completely refined but sufficient to do a test run. Alignment of braces will require some making on the sound board but maybe indexing point on the jigs be included. Initially used a t-slot cutter approach for the channels but two different straight cutters approaching the board from either side will suffice. Nuts were turned down slightly to improve channel entry. May have to include a frame that the template and workboard fit into to compensate for accumulative pressure on the template. Will keep you posted!
Tim
Tim
- Tod Gilding
Re: Good bye go bar?
Got Any More Pics Tim ?
- TimS
Clamps and braces removed.
Template removed
Underside of template
Glue line cleanup doesn't appear to be much of an issue.
Mad Scientist !
How is the adjustable neck going that you were working on last time I was around and you ended up with lots of my hardearned ?
- TimS
Neck joint Type 2 is done in my head but I just need some free time!
It works!DaveW wrote:Mad Scientist !
(Well, maybe that one was "Type 1")
Waiting patiently for the updates!TimS wrote:Will keep you posted!
- needsmorecowbel
Can't wait to see this build Tim,
Stu
Stu
A go-bar deck just seems so much simpler....
More than one way to skin a cat
Col
Col
- TimS
Yes I guess a Go Bar approach is quite simple. The only issues that i have come across are migration of braces during initial gluing and room to accommodate the jig. That being said the best method is the one that suits you which you are most comfortable with.
regards
Tim
regards
Tim
Interesting Tim. I might prefer something that ids more, I don't kow, spiderweb-like, so I can acccess the braces for glue clean up. (Mine don't come up that neat )
I will say, that I get very little sliding around of the braces, but I think that's because my sticks are timber, and cut just oversize, so the pressure isn't very sideways....
Yours seems to replace a vacuum clamping setup, rather than a go-bar deck.
Food for thought.
Food for thought.
I dont make acoustics, but this just seems like a really awkward way of doing things. You mention space for the jig if it's a go bar setup. What is above this jig that limits space if it was a go bar system? And cleaning dry glue is a much harder job, if the excess isnt wiped away when wet. Im sure I can see a gap under the X bar too.
- TimS
Thanks Perry regarding the X Brace area. However in this case the glue joint is fine. I used my 105mm macro and got down into the contact point (~40 mm) between the brace and the sound boated.
Hi Tim
Out of interest - how long did it take you to get everything glued up and tightened down.
Col
Col
TimS wrote:Thanks Perry regarding the X Brace area. However in this case the glue joint is fine. I used my 105mm macro and got down into the contact point (~40 mm) between the brace and the sound boated.
Looks perfect!
- TimS
Having already cut braces to size and the x brace half lap, applying glue and clamping would have been about 10 mins.
regards
Tim
regards
Tim
Hi Tim
just being another "prophet of doom"
it doesnt allow you to play around with the brace positions
cant forward /back shift the X brace ,cant alter the tone bars etc etc
it doesnt allow for much "artistic license"
sorry mate ...Im not a fan
you can beat me unmercifully next time I come around to buy wood !!
- TimS
Not quite sure about the etc etc etc etc. Thats not something I would glue on the sound board. The ability to move the tone bars around is, I would have thought, a decision that occurs well before the gluing phase after careful consideration about the effects of the previous build brace wood positions. It is actually very easy to move the x brace. It would probably be more of an issue with the two transverse braces above the sound hole. Fan club! This a forum for sharing ideas not attracting a devoted following. This is much in the same way that design ideas over the ages and across cultural divides in lutherie, have been the basis for inspiring, as of yet unanticipated connections. But wait! Type 2 Brace gluing jig is but two weeks away and this jig allows you to have infinite positions, complete gluing access and great visual access!
regards
Tim
regards
Tim
I'm in suspenders !!TimS wrote:But wait! Type 2 Brace gluing jig is but two weeks away and this jig allows you to have infinite positions, complete gluing access and great visual access!
Can't wait....
Don't tell me....
Not a...
Gobar deck??
Sorry, couldn't help myself... Must do more to encourage innovation around here....
TimTimS wrote:Maybe flat bar deck!
What if instead of the clamps you had a large bolt permanently fixed in each corner on the bottom board, and corresponding hole in the top board? Slip a small stand-off over the bolt slightly taller than the braces, brace it all up, slip the top board on over the bolts and put a nut and washer on each corner before tightening down all your brace bolts.
Col
- TimS
Maybe Col, however you would have to assume that the pressure would be even over all glued surfaces and this is invariably not possible. The varying downward movement of the soundboard into the built-in radius of the top, be it symmetric or asymmetric across it surface, and the deflection/flex of the jig.
regards
Tim
regards
Tim
- TimS
Just an edit to my last post.
There are at least two variables to consider that work against even clamping: 1. varying downward movement of the soundboard into the built-in radius of the top, be it symmetric or asymmetric across it surface , and 2. the deflection/flex of the jig.
I remember seeing a "mould"/"template" like this for sale on the German ebay a few years ago. It was made out of some kind of heavy rubber if my memory if correct. I believe it came from one of the old German factories that went belly up mostly likely in the 80's. Similar kind of steel string bracing pattern. Not sure how clamping would have worked.
- sebastiaan56
What about a system based on a series of bench dogs? The hardest bit making the arms long enough.
Users browsing this forum: Google and 35 guests
